Brake swap ?'s
So i have been reading up about brakes, and see alot of people with older bikes change to the newer Brembo brakes. so i have an 05 RKC and my cousin has a 2010 SG that he removed his front brakes to convert to single side. now what all would i need to swap his stuff over to mine? i have tried to google it but came up with nothing? a link would be nice to
From what I've been reading, and I could be way off here, is that to do the upgrade you need:
-The 2 front Brembo calipers
-All the brake lines that were with the Brembo system
-A master cylinder for the Brembo's (I believe. Someone chime in here)
-Both the front rotors from the Brembo setup (not sure on this one. Someone please chime in here)
I think that's about it. Please someone confirm/deny any of this as I would also like to know. I've been looking at doing this to my bike as well.
There are threads here that do this, as far as I remember, you need the complete set up, and the rotors too, they are a different diameter. The odd thing is that the levers will be different side to side as they changed a little with the Brembo changeover. To make all look the same you would need a clutch perch and lever.
