Rear brake light switch failure on an 08
Old 11-02-2013, 01:19 PM
btsom's Avatar
btsom
btsom is offline
Default Rear brake light switch failure on an 08
Road King. 5 years and 60,000 miles. No complaint, no problem, just a surprise. I had unknowingly been lazy. When mounting in the garage, I always held the front brake to steady things, and could see the brake and running light reflection on the wall and/or in a mirror. Turning the steering, I can see the headlight beam on another wall, so all lights checked...not so much. Never used the rear brake in the garage and usually disconnect the cruise with the front brake so I had unwittingly never confirmed the rear switch.
One thing I did on the new switch prior to installation was to fill the little chamber with brake fluid and kept the switch pointed straight up in a socket wrench to retain the fluid . Hopefully this will avoid the built in air bubble from the empty chamber in the switch. So far so good without any additional brake bleeding after installation.
VaDan
02-08-2017 05:20 PM
frenchbiker
10-26-2011 05:25 PM
kzoo
07-19-2011 08:56 AM
Rick-e
08-07-2010 12:57 PM
95Heritage
05-27-2007 09:46 AM
Quick Reply: Rear brake light switch failure on an 08
