Road King tire wear?
Old 01-22-2014, 05:25 PM
RK Fan's Avatar
RK Fan
RK Fan is offline
Default Did you buy the Road King new?
Originally Posted by Mike95376
I'm new to Harley's. My front tire is almost completely worn out on my 2010 Road King, almost 11K miles. You can still see the full tread pattern. I could go another 500 miles I think. But the rear is still looking very good, about 3/16" of tread left. I had a friend say he goes through 2 fronts for every rear tire. Does that sound reasonable?
I never had a motorcycle do that. Hmm. I'm not complaining.
Maybe the previous owner swapped out the front tire before he sold it?
Old 01-22-2014, 10:47 PM
GNrider's Avatar
GNrider
GNrider is offline
I only ran Metzlers on my last bike and learned quickley about inflation. First you have to keep them inflated, at least twice a month. Second whatever the max. presure is posted on the sidewall, that is what you run them at. That can vary between tire models with the same manufacturer. If you are seeing cupping, that can be a sign of under inflation.
If you keep your presures consistant, the bikes handeling will be consistant.
Hope this helps.
Old 01-22-2014, 10:54 PM
JCleary's Avatar
JCleary
JCleary is offline
Wow. On my baggers I've replaced them in sets, usually at about 7500 miles or so. The front sides are the first to go, but I do ride a lot of twisties.
Old 01-23-2014, 04:03 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,854 Likes on 2,420 Posts
Wink
Setting aside the mileage you have on it, your front tyre is knackered! So first thing to do is to arrange a replacement asap. That 500 miles you think you have could disappear in 100 or so, as in my experience that last bit of tread never lasts very long.
There are two things that affect mileage, the way each of us rides and pressures. You may be the last of the late breakers, for all we know! Check pressures regularly on your new tyre.
Old 01-23-2014, 07:40 AM
im's Avatar
im
im is offline
Without knowing detailed information it would be rather difficult to provide an accurate answer.
For example are you the original from the factory owner?
Reason: the previous owner might have changed tires at some point.
Are the tires on the bike the original Dunlops?
Reason: different brands may give different mileage.
Do you ride two-up or do you weigh 400+ pounds?
Weight can increase tire wear.
A bike that travels consistently in a high heat area is also exposing tires to searing road temperatures and may also increase wear.
As little as 10,000- 12,000 miles on a front tire and as little as 5,000-6,000 on a rear factory dunlop would not be unreasonable under mixed solo/two-up, mixed city/super slab riding.
There are riders that get significantly more miles with factory dunlops.
The front wearing before the rear would be rare unless you are doing some kind of trick riding.
Old 01-23-2014, 08:01 AM
foxtrapper's Avatar
foxtrapper
foxtrapper is offline
Received 1,334 Likes on 871 Posts
I agree, it's odd to wear the front out before the rear. Regardless, replace it.
As for reasons, low air pressure, dragging front brake, bad wheel bearings, etc. Almost all of which can be checked by simply jacking the front wheel off the ground.
If the bike was purchased used, it may be a red herring, as the rear may have already been replaced.
jrat69
The Dark Side
08-04-2015 07:54 AM
Mud_Bug
The Dark Side
02-26-2015 12:25 PM
stilup
04-09-2013 07:07 PM
rjmac53
03-06-2012 01:19 PM
ApeKing
09-27-2005 01:51 PM
Quick Reply: Road King tire wear?
