Oil Leak 2014 SGS
Old 02-02-2014, 03:39 AM
DeeRoe's Avatar
DeeRoe
DeeRoe is offline
Default Oil Leak 2014 SGS
Throttle was sticking on the SGS after about 2k miles. Went by the dealership to have them eff with it. I had recently changed the fluids in all three holes and checked all the fasteners myself, and had no issues other than the throttle.
I let the service guy that is a friend of mine take a look at it....and to just give it the once over from another perspective. He calls me back a few minutes later to show me some weeping around the oil cooler. There are two 1/2 inch (approx) allen screw ins at the top of the cooler and they looked like they had been weeping.
My bud told me this has been a minor problem, and the MoCo already has a replacement kit to replace some internal O rings and some gaskets. All covered under warranty.
Anyone else had this? Just kind of curious if this will be another recall item, or just a bad batch of coolers....
Old 02-02-2014, 09:36 AM
motorman4566's Avatar
motorman4566
motorman4566 is offline
Hum this could be what I saw on my 14 figured the shop spilled oil when servicing it. Have cleaned it up good..I'll keep an eye on it. Thanks for the heads up.
Old 02-02-2014, 09:41 AM
Drat's Avatar
Drat
Drat is offline
If it continues to leak after the o rings have been replaced, make sure that the adapter is completely tight. That would be the center threaded piece that your filter screws on. It does loosen up and will leak around the filter gasket as the filter will fibrate loose. Only takes a second to check and tighten when you drop that filter. It takes a 7/16ths hex or you can use a 1/4 bolt head in a pinch.
Old 02-02-2014, 04:00 PM
DeeRoe's Avatar
DeeRoe
DeeRoe is offline
Thanks for the info on that......I seem to remember having to do that when I put an oil cooler on my 07 FLHTCUI
Old 02-02-2014, 04:37 PM
xhere's Avatar
xhere
xhere is offline
I saw the same thing on mine and also thought it was from the 1k service...
Old 02-02-2014, 04:51 PM
Webo's Avatar
Webo
Webo is offline
I haven't seen anything that looked like a leak yet but I'll keep a close eye on it now, thanks for the heads up! Was it enough to drip on the floor or just give the wet appearance around the bolts?
Old 02-03-2014, 04:27 PM
DeeRoe's Avatar
DeeRoe
DeeRoe is offline
I too had just done the oil change prior to a 1200 mile ride. Didin't notice any drips. As I said, it was pointed out to me by my mechanic friend. Wasn't gushing like a Clampett oil well....just wet around it.....
Old 02-03-2014, 10:06 PM
Gunnerdave98's Avatar
Gunnerdave98
Gunnerdave98 is offline
Appreciate you putting this out there. Will make sure to keep an eye on mine now too.
Old 02-03-2014, 10:40 PM
terryrh's Avatar
terryrh
terryrh is offline
Heading to garage now.
Old 02-04-2014, 04:57 AM
Rustrtal's Avatar
Rustrtal
Rustrtal is offline
Nothing on mine...yet.
Quick Reply: Oil Leak 2014 SGS
