Dunlop 2nd Generation American Elite
  #41
Old 09-22-2014, 02:39 PM
son of the hounds's Avatar
son of the hounds
son of the hounds is online now
Received 2,527 Likes on 1,307 Posts
I was going to put on Commander II's, but they were in short supply just prior to Sturgis so I read up and opted for the Elites. 10,000 miles later and they have ended up being good tires. I'll probably stay with them next go around. Ridden through pouring rain to fast and hard twisties. My confidence is only shaken by an occasional unseen tar snake in the corners. But even here, they seem solid enough. They really show no wear yet, but I have not measured the tread depth. I washed the bike Sunday after a long and bug ridden ride and I looked at the tires then and felt they still have deep grooves.
  #42
Old 09-22-2014, 03:46 PM
mitch1189's Avatar
mitch1189
mitch1189 is offline
Stage III
thanks Blue 66 - appreciate your response!
  #43
Old 09-22-2014, 05:33 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
beware of tubes from drag specialties,I've had 2 flats from defective tubes. and to the tire novice your wheel is 3.5-16 not 5.5-16. i now get my tubed from honda much better tube and has a really nice long 90 on the valve stem.
  #44
Old 09-23-2014, 02:46 PM
BOARGAURD's Avatar
BOARGAURD
BOARGAURD is offline
Just put a set of Americn Eagles on my CUSE2 and it is a very positive feeling of being glued to the ground. If they end up lasting like many have said this will be my tire of choice going forward. I did install a 150/80-16 on the stock rear wheel without modifications and no rubbing.
  #45
Old 09-24-2014, 02:46 PM
mitch1189's Avatar
mitch1189
Stage III
Big - the tube size I quoted was taken off of the invoice from the dealer that installed my tires. Could they have used the wrong tube - or is the invoice just wrong.
Also, when you had defective tubes how long did it take before they gave out?
Appreciate your help.
checkers
Wheels/Tires
09-13-2016 07:28 PM
Falcon195
04-06-2015 05:48 PM
Hitechluddite
10-14-2012 06:30 AM
rjmac53
03-06-2012 01:19 PM
hotshot
10-17-2009 07:12 AM
Quick Reply: Dunlop 2nd Generation American Elite
