Need Suspension help on 2013 Road King
I changed to the profile low rear shocks for the same reason on my 2014 road king. some complain they are too harsh but I like em.
Received 1,507 Likes
If you are serious about IMPROVING the handling characteristics of your 2013 Road King, then you need to investigate options outside the MoCo. There are two options for rear shocks that will help, Ohlin's or JRI shocks, anything else, will only help a little bit. The front forks can be improved by adding RaceTech Gold Top Emulators and springs, or Progressive Mono Tubes.
There is a sponsor of this Forum, MotorcycleMetal, Howard is the man to talk to about shocks and forks. www.motorcyclemetal.com. Check out his website and learn about Harley suspension. I am not paid by him, not do I work for him. I am just a very happy customer.
I've purchased the JRI-B shocks from them and it made my 2011 FLTRU feel like it should! Bumps are absorbed, the bike tracks true, bumps in a corner do not throw it off balance or the line. Serious improvements can be had, but you need to be serious about the set-up and the investment. Just lowering the rear of the bike is just going to reduce the amount of travel in your shocks. Less travel, equals less movement before your shock bottoms out!
I had a 2006 Road King Classic, and put coil-over shocks by Race Tech on it that were non-adjustable except for spring pre-load, and they worked very well too. Junk those wimpy air bladder shocks that come stock, and get a good set of coil-over adjustable shocks and you will be much happier.
Good Luck,
John
Good Luck,
John
Good Luck,
John
Good Luck,
John
This is (mostly) a 2-up bike. Rider+passenger=350 lbs.
As it sits, the wallow factor is relatively high. Almost anything would be an improvement.
I took a look at the Progressive monotubes. Seems like they get good reviews.
My target is < $1,000.... so I'm not THAT serious. This is a touring bike that we use for, well, "touring". Speed limit+5 and +15 in the corners.
Rear shocks are your most felt ride improvement. Check out the JRI shocks. Ohlin's are more expensive, but are about the same ride quality. Progressive shocks are "OK" but not much better than stock. I'm just trying to keep you from spending money on generic stuff that doesn't do the job, then you have to spend more to replace that stuff.
One time investment in premium shock absorbers will put a smile on your face. Your passenger will like it too. Spend time on the phone with Howard at motorcycle metal, he may be out in Sturgis now, maybe not, but call him. The man knows suspension!
John
John
I would first experiment with the air pressure in the stock shocks, I liked to run around 40 pounds at least that worked for me. I now have the HD premium hand adjustable shocks which you can purchase for about 400 dollars. I like the HD shocks and they're a bargain, have had them on the bike 12k miles and it's a big improvement over stock.
