Handle bar adjustment or replace
I just picked up the 17 tri glide and the Handel bars are really low I was able to raise them slightly by removing the ignition lock and shield and loosening two hex bolts
But the fairing is preventing my from raising them to where I would like them
Question is the fairing adjustable so I can adjust the bars ???
Or should I look at replacing the bars altogether ???
I had a 07 road king classic that I changed the stock bars to heritage bars on
Any suggestions ????
Fearless (old nickname) (07-05-2017)
Search for some of the threads here and in the touring forums, a lot of discussion about bars. Seems like most folks go with the Khrome Werks 2+2s, either wide sweepers, or their narrow sweepers (like I did.) Save big bucks and do it yourself, if you had no issue adjusting the stock ones, it's a relatively easy job.
Grumpy7760 (07-04-2017)
These worked out perfect for me
back far enough I don't stretch to reach
Perfect height to keep cold air off knuckles in cold weather
Fearless (old nickname) (07-23-2017)
GuitarKidd
2014-2023 Touring Models
17
04-19-2019 12:11 PM
iwillfixthem4u
11
09-01-2015 07:20 PM
