Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri Glide Trunk Issues
Old 01-24-2017, 02:07 PM
Garinsr's Avatar
Garinsr
Garinsr is offline
Default Tri Glide trunk issue
Don't know why but suddenly my trunk would not stay closed. After getting home I made a small adjustment to the lock pin (loosen the 1/2" nut, turn pin 3/4 turn counter clockwise, tighten 1/2" nut and voila, it locks again. I have never done anything to the trunk and only have 1300 miles on the bike.
Old 01-26-2017, 11:52 AM
Garinsr's Avatar
Garinsr
Garinsr is offline
Wink tri glide trunk issues
As a side note, there is nothing in the supplied tool kit to fit the locknut. I would recommend getting a small wrench set, or a small thin adjustable wrench to keep in the bike.
Muffbrorick (01-26-2017)
Old 03-22-2019, 10:54 AM
Diana Lynn's Avatar
Diana Lynn
Diana Lynn is offline
Stage I
I have the same problem of keeping my trunk lid closed. After reading your post I went and looked at the pin and saw it was wore out where it meets the latch. I bought the trike used and maybe the previous owner was not closing it properly. I am going to try to turn the pin like you suggested to see if that works. Thank you for your suggestion.
Old 03-23-2019, 09:15 AM
470004's Avatar
470004
470004 is offline
Received 15,118 Likes on 6,252 Posts
I gently push the trunk door close and then push the trunk door below the lock until I hear another click.
Harleyrider15
General Topics/Tech Tips
08-18-2015 09:22 PM
JimRicker
15
03-15-2015 08:18 PM
biil9
10-08-2012 02:04 PM
epittman15
09-30-2010 11:29 AM
royston
04-06-2010 12:09 AM
Quick Reply: Tri Glide Trunk Issues
