Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
won't start
Old 08-21-2017, 08:47 AM
handdw's Avatar
handdw
handdw is offline
Default won't start
Well....putting on my new avon grips and now when I turn the ****, hit the ignition switch and won't start. It makes the power up noise when you turn the know but nothing comes on the screen...
Not sure if it's something on the throttle side or clutch side that is messed up.
Old 08-21-2017, 09:00 AM
Cool Inferno's Avatar
Cool Inferno
Cool Inferno is offline
I would start with checking the fuses and looking for pinched wires.
Old 08-21-2017, 10:02 AM
handdw's Avatar
handdw
handdw is offline
Checked all fuses and they are fine and all the wires look fine
Old 08-21-2017, 11:59 AM
NHBAGGER's Avatar
NHBAGGER
NHBAGGER is offline
Could be on the clutch side. Have you tried staring in gear with the clutch pulled in and your foot on the brake?
Old 08-21-2017, 01:41 PM
handdw's Avatar
handdw
handdw is offline
Well after cutting an inch off the heal shrink wrap looking for a crimped wire I then went to the clutch side loosened it all up and it started.
Tightened it all back up and continues to start.
of course now have to get more heat shrink to cover the part I cut.....
thanks all....
Old 08-21-2017, 01:50 PM
handdw's Avatar
handdw
handdw is offline
To good to be true... now engine light on
Old 08-21-2017, 04:21 PM
Cool Inferno
Could be a historical code sent when you had the error. Check the code first and then clear it.
Old 08-21-2017, 06:07 PM
handdw's Avatar
handdw
handdw is offline
These are the codes I had:
ECM
U0001
U0140
U0141
U0142
U0156
BCM
62208
U0001
Went thru and cleared them and the engine light went off and those codes did not come back EXCEPT BCM 62208 that one even when I hit "clear" will not go away.
Old 08-21-2017, 06:38 PM
neon65's Avatar
neon65
neon65 is offline
The apt on my phone for DTC codes keeps coming up with battery voltage low??
Old 08-21-2017, 09:56 PM
Cool Inferno
Check out this thread. Talks about a short. https://www.hdforums.com/forum/new-r...ode-p1356.html
Quick Reply: won't start
