2010 Tri Glide exhaust change over
I was thinking of changing my stock mufflers over to something a little more exciting. I noticed that the stock left muffler is different than the right side.
The right side seems to be straight through design, but the left side has a plug inside about 8" in. I was wondering if this is there for a reason?
What will work on a 2010 Tri Glide? Do I have to change the head pipes or can I just use the slip on kind of muffler?
Has any one used the Cobra Tri-Ovals on their trike and how do you like them?
Any help would be appreciated. Thanks!
pipes
I think most touring pipes will fit, I have the Kerkers off of my 04 Electra Glide on my 11 Tri Glide and they slip right on brackets are the same and length is the same. I also noticed that the stock pipes had different baffels but for what reason I don't know probably to equalize back pressure if one pipe is shorter than the other but I have never heard of this being an issue with replacement pipes.
Is there something I'm missing here? About a couple years back, I got the Fuelmoto headpipe, Supertrapp SE mufflers and PC V fuel management. I don't remember anything about a "left" and "right" muffler. Never saw anything stamped on each muffler. I might be losing power if they aren't matched(?)
Harley has been doing this for years with the right muffler having less baffling then the left on stock touring exhaust systems. It keeps the bulk of the exhaust flowing out the rightside and the baffle in the left doesnt allow "reversion" to create a decel pop but still flow some exhaust out.
If you ever are around someone who still has the stock system with dual mufflers and you put your hand behind the two mufflers while its running and have them rev the engine you will feel the difference
Does the trike have to be reprogrammed?
