Oil dip sticks
Oil dip sticks
Just finished doing an oil change before my extended road trip next week. I have 2 oil dip sticks, the stock one and the digital gauge. I use the stock one when measuring the oil I put in. Did it by the book, took it for a warm up spin, and topped the oil off. Perfect. Replaced the stock with the digital and later when I took a ride and got it nice and hot, pressed the button and the gauge shows HI OIL. I put the stock gauge in and it shows the oil level at the full when hot mark. Don't know why I never checked the sticks before. The digital one is for the Trike.
On another note, I know these engines are supposed to hold 4 quarts; but, I have never used more then 3. Wonder where the other quart is hiding.
lots of people run their bikes about 1/2 way up the stick when hot. supposed to prevent blow by into air cleaner. as most of the newer bikes use very little oil, running a little below full should not cause problems like having to add oil while on a trip--oil level usually stays right where it was when you left home.
Rumor has it... Rumor has it....
Fresh from the rumor mill and a Harley PHD extended education class. All new Harley oil dipsticks are marked wrong. Run all Harley Touring dipsticks 1/2 qt low to be at the recommended Fill Level.
Service Bulletin = None.
Harley's Stance = Educate Customer.
Harley's Problem= Too Cheap to replace them all.
