Twin Cam Motors Twin Cam 1998 thru 2017
tach wiring has anyone ever set one of these up?
Old Mar 24, 2025 | 10:13 PM
Gambitr777's Avatar
Gambitr777
Default tach wiring has anyone ever set one of these up?
I have a new tach on my bike with an rpm guage the sell a separate wire for some models. where does the wire usually get it s signal from?
I have a 2002 RK
Attached Thumbnails tach wiring has anyone ever set one of these up?-download.png
Old Mar 25, 2025 | 10:58 AM
Max Headflow's Avatar
Max Headflow
I've not done that tach but have added a separate tach to a 2002 RKC. If you can find the instructions, it will describe the connection. Typically you need to connect the pink wire to speedo. IIRC it runs to the headlight nacelle which where the police bikes wired in the tach. Look at the wiring diagram in the SM or pull it off of the HD service sight.
Old Mar 25, 2025 | 03:32 PM
Gambitr777's Avatar
Gambitr777
Makes sense, thank you for info.
Old Mar 26, 2025 | 09:49 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Doesn't the tach signal come from the yellow wire..? A wiring schematic would be very helpful here..
Old Mar 26, 2025 | 05:37 PM
Max Headflow
Might be for an evo but..
Old Mar 27, 2025 | 07:05 AM
eighteight's Avatar
eighteight
FWIW
`99 the wire is pink , found unused in the harness that runs to the speedo.
Iron Horse 13
Mar 12, 2022 11:44 AM
Sal C
Aug 28, 2020 10:51 PM
jbied
Mar 18, 2009 04:25 PM
90ssharley
Electrical/Lighting/Alarm
Mar 17, 2009 09:55 AM
90ssharley
Mar 15, 2009 12:03 PM
