16 rear on a dyna
04-13-2018, 10:09 PM
16 rear on a dyna
I just got a set of amf 9 spoke wheels off a guy locally. The front is 19 and the rear is 16. Other than a new rear tire what will I need to make this set up work? I dont have abs if that makes a difference.
04-13-2018, 10:14 PM
how are we suppose to know, if you dont tell us what you're trying to put them on?
04-13-2018, 10:16 PM
Quote:
Originally Posted by
2500hdon37s
my bad 13 fxdb
04-13-2018, 10:45 PM
The wheels are from an fxr
04-14-2018, 08:43 AM
Might be wrong, but I don't think you're going to want to do what it will take to install those 99-earlier (technically 9-spoke is 95-earlier) wheels with 3/4" Tapered wheel bearings on your 25mm sealed bearing mid-glide bike
04-14-2018, 10:01 AM
multihdrdr
Cant just swap bearings?
04-14-2018, 10:07 AM
Nate8604
Can’t just swap bearings?
Swapping bearings wouldn't fall under
"do what it will take to install" , that's simple stuff
No, the Tapered Bearing and Your Sealed Ball bearing have different ODs (outside diameter)
You would have to stay with the 3/4" and work around that
04-14-2018, 10:17 AM
multihdrdr
what about machining to match the od
04-14-2018, 10:22 AM
Maybe, but you would lose your pulley/rotor locator on the hub
04-14-2018, 11:53 AM
multihdrdr
youre right I just went down to one of the shops I use and he said not gonna happen without milling a premade set of bearings.
gmkavas
General Topics/Tech Tips
02-12-2019 02:49 PM
artsbest
12-24-2018 09:31 PM
fenwick
12-03-2018 05:12 AM
No U Glider
10-23-2018 05:13 PM
bykw2
01-08-2018 12:31 PM
