Enforcer wheels
Old Dec 2, 2018 | 09:23 AM
fenwick's Avatar
fenwick
Default Enforcer wheels
I see a great deal on a set of enforcer rims off a 2018 street glide[non-abs, I know I can change the bearing]. Will they fit my 08?
Old Dec 2, 2018 | 09:32 AM
23Seven's Avatar
23Seven
The rear is wider on 09 and up. You would need to do some serious mods to swingarm and rear fender.
Old Dec 2, 2018 | 09:37 AM
fenwick's Avatar
fenwick
ok tks what about the front?
Old Dec 2, 2018 | 09:40 AM
23Seven's Avatar
23Seven
Not sure on front. I believe your 08 has a 16” and the 18 has a 19”. The width should be the same.
Old Dec 2, 2018 | 09:47 AM
23Seven's Avatar
23Seven
Front is a 17”... Lower profile tire than 16” should be okay.
Old Dec 2, 2018 | 04:37 PM
skratch's Avatar
skratch
for reference, the 16'', 17'', 18'', and even 19'' touring tires are all virtually the same overall diameter. to further make things easier, the fork lowers have been the same since, somewhere around 1998 until the rushmores. so you just have to make sure that you've got the right bearings and spacers for your axle.
Old Dec 2, 2018 | 05:46 PM
cncmike's Avatar
cncmike
The front on a 2018 Streetglide is 19”. If you have Brembo calipers all you need is ABS bearings and it will bolt on.
Old Dec 3, 2018 | 05:12 AM
caulk04's Avatar
caulk04
You'll need the appropriate rotors for the Enforcer as well...just in case you overlooked that.
Buy bearings for your bike, they'll fit that wheel.
gmkavas
General Topics/Tech Tips
Feb 12, 2019 02:49 PM
gelliottjr79
Touring Parts
Dec 6, 2018 07:02 AM
Nate8604
Wheels/Tires
Apr 14, 2018 11:53 AM
joe98
Jan 12, 2013 05:22 PM
buckler27
May 15, 2009 09:00 AM
