Can this be right?
Old 02-13-2019, 03:03 PM
bustert's Avatar
bustert
bustert is offline
Talking
well mr kevin,
i was saving my dandelions for wine but your deal is even better, how about a bushel for the work?
Old 02-13-2019, 07:02 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
4 bearings Non abs @ $19.50 = $78.00
1 Rear tire = 277.00
1 hour labor = 100.00
Total = $455.00
Prices from Ronnies. Both bearings must be removed because the bearing that replaced the ABS bearing gets pressed in first. Then the remaining bearing gets pressed in to the wheel. The inside spacer is the same for ABS & Non abs wheels. The axle spacers from your existing non abs wheels should be right. The shop may have told you that you need a spacer because you would not have a ABS wheel speed sensor which replaces one axle spacer on abs bikes.
Old 02-13-2019, 07:49 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,240 Likes on 1,816 Posts
Originally Posted by 14GuineaPig
... Both bearings must be removed because the bearing that replaced the ABS bearing gets pressed in first. Then the remaining bearing gets pressed in to the wheel...
Just for General info ...
One can change the "Secondary" Bearing ONLY, but they need to change your installation process and the result will effectively be the same as the "Proper" procedure.
Also to add, I would only do this on a Low Low mileage wheel (bearings) and with the same bearings.
Old 02-13-2019, 07:51 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by Schex
delete
EDIT: another "add"...
You can use wheels with ABS bearings on NON-Abs Bikes by using "Reduced Length" Spacers against the ABS bearing
Old 02-22-2019, 10:22 AM
RED_5's Avatar
RED_5
RED_5 is offline
I wondered that. Already had the bearings replaced on my rims.
For future reference, where does one get these spacers? What size?
Papamud
Shovelhead
10-06-2018 12:41 AM
BigDansHarley
09-18-2015 10:00 AM
cajun1957a
Shovelhead
11-02-2014 04:50 PM
canuuk01
06-28-2014 08:34 PM
CT-Bagger
01-19-2014 04:53 PM
Quick Reply: Can this be right?
