Replacing steering head bearings...
Old Oct 4, 2018 | 08:20 AM
Papamud's Avatar
Papamud
6th Gear
Default Replacing steering head bearings...
Hi folks,
So I got a flat tire in Baltimore yesterday and removed the wheel to take to my local indy for a new tire. I suspect the tire is fine and it is a rusty rim that is the problem... regardless, they'll let me know.
My question is this. The bike is a '75 fxe and it steers like a GD whale, so I am going to use this to replace the steering head bearings. I've searched the threads here and couldn't find anything on what I need to replace.
I've found wildly different prices on the bearings themselves, and I'm hoping to do this job Saturday afternoon, so I could use some advice quick! Do I need to replace seals and bearings? Just bearings? Races too? I have a service manual and feel confident I can handle the job, I've just never done them before.
Thanks!
Papa
Old Oct 4, 2018 | 12:14 PM
pjb's Avatar
pjb
new bearings won't hurt. I did mine because I was doing just about everything else on the bike. But, do you really need new bearings?
What were your tire pressures like when you say it rode like a whale. Low tire pressure will make it ride horrible.
Old Oct 4, 2018 | 12:15 PM
pjb's Avatar
pjb
I had to buy a special tool for the bearings/races.
About $50
Old Oct 4, 2018 | 12:27 PM
Papamud's Avatar
Papamud
6th Gear
Nah, it steered like hell even fully inflated. Wandered a lot and turns were jerky... This bike has had very little maintenance but a lot of riding over the last decade, so... it's time to start going over it as fast as $$ allows.
Old Oct 4, 2018 | 12:28 PM
Papamud's Avatar
Papamud
6th Gear
Which tool? Thanks!
Old Oct 5, 2018 | 07:07 AM
pjb's Avatar
pjb
check out Georges garage for the steering head race tool.
you may want to look at your forks.
drain and refill
Old Oct 5, 2018 | 08:07 AM
biginchhustler's Avatar
biginchhustler
a friend of mine worked at a boat trailer place in the 70's - the wheel bearings that fit a skipper "B" boat trailer are the same bearings that fit the Harley neck cups for the front end..
Old Oct 5, 2018 | 12:48 PM
carlgrover's Avatar
carlgrover
I would pull the bearings out, clean them, then inspect them before making the decision to replace. chances are good that the bearings just need fresh grease packed in them. I never replaced the swingarm bearings in my shovel and they were original from 1973. Looked great after I cleaned all that old snot out of them.
carl
Old Oct 5, 2018 | 04:04 PM
johnjzjz's Avatar
johnjzjz
we weld them the races and they fall out - the race shrinks
but we have the tool - on an original piece that has patina we leave the cups in place
Old Oct 6, 2018 | 12:41 AM
TwiZted Biker's Avatar
TwiZted Biker
I have with OEM head cups knocked them out then drilled 2 small holes on the shoulder just over the race then punched them out before I had access to a welder.
C908
Aug 9, 2017 09:31 AM
leafman60
Apr 16, 2017 11:02 AM
CT-Bagger
Jan 19, 2014 04:53 PM
the_ogre25
EVO
30
Nov 23, 2009 12:20 PM
ArkyDave
Jun 2, 2009 11:24 PM
