Sony MEX-70BT
Sony MEX-70BT
Quick question, using the RCA outs on the in-dash radio into an amp, is there a workaround to get line outputs to work still for standard tweeter bars that still need line out watts from the head unit. Seems the use of RCA's outs on the 70BT head unit shuts off all line outputs in the front and rear channels?
I think more and more are going to go to this setup. Alpine has been doing this for a couple of years now. If you want full output from the RCAs then the option to disable the internal amp of the head unit is there to assist with that.
I didn't think the Sony line-up was doing that though.
