15' RGS Upgrade ?s
Old 02-01-2016, 04:55 PM
LL247's Avatar
LL247
LL247 is offline
Former Sponsor
Originally Posted by JimTJr
Hmm,, me too I guess!
I'll do it when I get my new speaker from BT!
I see in your sig you have the flash and bin file...if you haven't already done so get the BT line leveler. Makes a big difference!
  #32
Old 02-06-2016, 10:02 AM
js198027's Avatar
js198027
js198027 is offline
Took the fairing back off yesterday and pulled the pods apart and ran a bead of silicon around them. Even took a file to the surface where the speaker mounts just to give a little more room for the grills. Then put it all together and added a small amount of poly fill to the pods. Now if I could just make it spring and the snow go away
  #33
Old 02-06-2016, 10:51 AM
Bertk's Avatar
Bertk
Bertk is offline
I have heard there is a noticeable improvement in sound quality after sealing those pods up. Give the silicon time to fully dry and try them out. By the way, what speaker and amp did you end up going with?
  #34
Old 02-06-2016, 10:10 PM
js198027's Avatar
js198027
js198027 is offline
Went with the B52,kappas and a BT line leveler.
  #35
Old 02-07-2016, 09:32 AM
Bertk's Avatar
Bertk
Bertk is offline
Those Kappa's should be screaming with that amp.
  #36
Old 02-11-2016, 03:04 PM
wevsspot's Avatar
wevsspot
wevsspot is offline
Is the pod removal/disassembly process "self explaining" once you get into it? Any special instructions or warnings?
  #37
Old 02-11-2016, 03:07 PM
TomboAT65's Avatar
TomboAT65
TomboAT65 is offline
Super easy. There's 5 screws holding them in, 2 on top and 3 on the bottom. Then 7 that hold it together. On the inside half there's a channel you can run the silicone in.
Just make sure not to seal the port on the bottom. And get a little extra in the top leg that goes around the air scoop.
  #38
Old 02-11-2016, 03:34 PM
quinton82's Avatar
quinton82
quinton82 is offline
Originally Posted by timbo141
If I were you I would really consider the Biketronics 2015 and up Road Glide upgrade package.
http://www.biketronics.com/2015-and-...eaker-package/
Lifetime warranty, and pretty kick *** system. They are also coming out with their version of the magicbox. So no hassle on the flash.
There is a discount for being a forum member.
Good luck in your decision.
This and they have a coupon that takes off around 70 bucks. forgot the code tho Sorry.
  #39
Old 02-11-2016, 04:08 PM
quinton82's Avatar
quinton82
RGorg coupon code
iclick
01-27-2016 08:28 AM
Jagpanzer
Audio Systems
10-11-2014 08:30 AM
BlessedHellride
Audio Systems
05-05-2014 09:31 AM
Kingfever
Audio Systems
27
12-24-2013 03:44 PM
Bagger_Vance
Audio Systems
10-03-2013 05:01 PM
Quick Reply: 15' RGS Upgrade ?s
