On my 2014 Limited I have upgraded both front and rears to the Boom speakers (no amp). I know not everyone digs these speakers but I got a decent deal on them and can definitely tell a difference from stock so for now I'd like to keep them. My understanding is that these are 75w speakers.
I'm looking for some advice on an amp to power them to their full potential. I'd like to have a single amp that could power all 4 speakers (I've read much talk on having two amps but not sure I need or want that.)
There is the HD amp as an option and I know of many other names out there but I get lost on the proper model numbers and ratings that fit the bill. Help!
Assuming I'm not going to change out the speakers and would like to install a single amp for the entire bike, can I get some suggestions?
I apologize if this should be in the 2014 sound upgrade thread but that thing is unwieldy as all get out for asking a specific question!
I'm sure there will be a few on here that will tell you "get your money back", but as long as you are happy.
I think any amp you pair with these will have a good chance at blowing the speaker. 75W is just not very powerful. I'm no expert but I think you always want to run your speakers no higher than the max RMS output of the amp or BOOM! You blow your speakers. For 4 speakers you will want a 4 channel amp. A class D amp and you run the risk of blocking your FM signal so no radio reception.
Good Luck.
Point(s) taken. Thanks for the thoughts. I'm guessing my only safe option is to find a 300W, 4 channel amplifier. I've found a few but most distinguish between ratings at 2ohm and 4ohm. I'm unsure of these speaker ratings.
Are these what you have? 6.5" Fairing Speakers part# 76000317
If so I think they are 2 ohm speakers and will effect your decision.
Yes - that is the part number. Funny I just posted about the 2ohm vs. 4ohm and I was going to guess 2ohm from a few things I found but couldn't find anything definitive.
Thanks to all!
Are you sure the boom speakers are rated at 75 watts RMS? No one has been able to verify that number. Anyway if you don't care about radio reception the only amp I can think of to put on the booms is the Sound stream Picasso Nano PN4.320D. 80 x 4 @ 2 Ohms.
Maybe I'm not stating the right numbers. I was going by the HD website for the speakers that says they have 75w of power per speaker. And the amp page says it is 300w delivering 75w per channel.
As always Harley Davidson is a little misleading with their specs. If you notice on the speaker page they say "75 watts of power in each speaker" which means absolutely nothing. Are they talking RMS or Peak Power? However, I do see where they claim their amp is producing 75 watts to each speaker @ 2 ohms. I'm not sure what kind of deal you got but they list for $199.00 bucks. No way I would pay 200.00 bucks for that speaker.
You mention a two speaker setup. On a 4 speaker bike is the thought you only really need to make the fronts top-notch as the rears don't play as big of a role in what you hear at speed?
If you go with a 2 channel amp that only drives the fronts I'm assuming you need the flash from HD to disable the internal amp so it works properly? If that's the case what drives the rears from that point on? Is it just the stock head unit? If so, with the internal amp disabled it would seem they'd be really quiet? I'm a little confused on how that all works.
Thanks for the thoughts and comments.
Sorry Jag I reply to so many post I think I got confused on your set up. I do see where your system is a 4 speaker system. There is a 2014 sticky at the top of the forum that would be helpful to read. If you already have the booms and do not want to upgrade, The soundsteam PN4.320D is probably going to be your best bet. The problem is nobody knows how much power the boom speakers will take because Harley does not post the real specs. What we do know is their amps are only pushing 40 watts per channel which gives you some indication of the speaker specs. I think you will be ok with an 80 x 4 @ 2 ohms amp if you keep the gains low. Keep in mind the soundstream amps are class D and you are subject to lose radio reception. But I can't think of another amp to put on those speakers without blowing the voice coils. The Rockford PBR300X2 (2) would totally fry those speakers at 2 ohms and the Harley amp at 40 watts is useless. Hopefully some of my friends will chime in with a solution. If it were me I would just go with better speakers and sell the booms.
