Anyone using Sony DSX-S100 or similar??
Old 05-23-2013, 06:10 AM
UltraDune's Avatar
UltraDune
UltraDune is offline
Default Anyone using Sony DSX-S100 or similar??
I have this Sony head-unit installed in my '11 RGC along with a RF amp and the Biketronics control unit. Question about the Sony unit and hopefully someone has an answer. I can scroll through the set-up options to take the 'beep' out, as in turn it off so that everytime you change volume/channel etc. there is no 'beep'...but everytime I turn the bike off and the unit loses power it gives out about six loud beeps or so, the manual claims this is the alarm on the radio. I do have an ipod inside the tray. The manual claims that it only will beep if you are using the internal amp??
Anyone know how to turn this off? Its driving me nuts everytime I shut the bike down....Anyone? Thanks in advance!
Old 05-23-2013, 06:24 AM
elPrez's Avatar
elPrez
elPrez is offline
It's a Sony thing...does it on all the recent units I've had...yeah it's annoying and I don't know if you can shut it off. I also hat that the time display is just about unreadable unless the unit is turned off, yeah I get it that it's not built for motorcycles but my eyes have a hard time reading the display when music is playing.
Old 05-24-2013, 11:59 AM
BeerIsMyDad's Avatar
BeerIsMyDad
BeerIsMyDad is offline
6th Gear
Unfortunately, the "Device Inside" beeps can't be turned off on the DSX-S100. The sound only comes through the speaker wires though, and if you add an amp using just the pre-amp outputs of the radio, you can defeat this sound. The DSX-S310 has an option to turn this annoying feature off and is roughly the same radio with more features.
Old 05-26-2013, 08:27 AM
elPrez's Avatar
elPrez
elPrez is offline
The fix might work but I don't think it's a "device inside" reminder because I have two other Sony units without the tune tray (just cd player) and they do it too...
Old 05-26-2013, 04:16 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
on the newer units, you can turn it off but on the 100 you cannot unless you go with an amp and the amp has to be connected via the RCA cables. If you use the high level inputs on an amp connected to the speaker wires the sound will still come through.
Yeah most aftermarket head unit displays are going to be pretty much useless during the day but then again that's what the handlebar controls are for.
Old 05-29-2013, 09:20 AM
elPrez's Avatar
elPrez
elPrez is offline
My problem with the display is
1: curved plastic make the light wash it out and most importantly
2: when music is playing, the clock gets very small and I cant really see it at all, with the ipod in the large display is the time counter for the song...don't really care about that. Wish there was a way to choose what options you want on the display
Old 05-29-2013, 10:46 AM
UltraNutZ's Avatar
UltraNutZ
clock? who needs a clock on a Harley... you must be married.. LOL
There should be a clock on the odometer display as well.
Old 05-29-2013, 05:51 PM
elPrez's Avatar
elPrez
elPrez is offline
I am...but I also still need to be some places on time and 05's don't have clocks on the odometer...
Old 05-30-2013, 11:02 AM
BeerIsMyDad
6th Gear
The Sony DSX-MS60 has all the same features as the S100, but in "marine grade" (yeah right). The advantage is the high contrast display that is actually easier to read at different angles and in bright sun.
tylerfj24
Audio Systems
07-16-2019 08:16 PM
Beardedglitcher
Audio Systems
09-27-2017 08:09 AM
UltraDune
Audio Systems
03-25-2015 04:45 PM
cfmii11
06-08-2011 12:24 PM
Ricks07
10-27-2008 11:57 PM
Quick Reply: Anyone using Sony DSX-S100 or similar??
