Volume Differences BT vs Radio
Old Jun 21, 2019 | 09:49 PM
tylerfj24's Avatar
tylerfj24
Default Volume Differences BT vs Radio
Ok so I have a 18 SGS with the 6.5gt radio headunit. It didnt matter whether it was stock or with amp and diff speakers. My issue is the sound of the music, it is substantially different when listening to radio vs the bluetooth from the phone.. The phone is much much lower than the radio.. If I turn the music back to the radio its extremely loud..
Is everyones systems like this? Is there a trick to getting the bluetooth to be just as loud as the radio or match the amp at least? Is this making sense?
ALSO I do know that there is a volume on the phone, I have it turned all the way up and the SQ deminishes, so i tried to set the amp up with it 1/2 way like it should be and the sound quality is much much better but like i said the differences in volume is astonishing..
Does anyone know if I plugged the phone in directly would that make a difference? just wondering if I should buy a cord and try it..
Old Jun 21, 2019 | 10:20 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Tyler what make and model of phone are you using? I have found that Android phones often don't sound as good as iPhones do on the same system. On my Galaxy S7 I found that some EQ settings had been enabled that lowered the overall volume level. When I set the EQ to disabled or flat the overall volume level increased noticeably.
Old Jun 22, 2019 | 12:25 AM
IArider1's Avatar
IArider1
I also noticed that when I had my stock head unit on my bike. I quit using Bluetooth after that and just directly plugged it in with the usb cord.
With Bluetooth though when playing music through a stereo you want to have your volume on the phone 1 notch from max. Or like you noticed sound quality diminishes.
Old Jun 22, 2019 | 07:28 AM
Babyboy's Avatar
Babyboy
Tyler
Make sure the volume of the phone in use is turned up when connected to the HU. My android phone goes to default volume setting (which is about half) when connected the first time.
As noted run the phone volume 1 click below max
Old Jul 16, 2019 | 08:15 PM
tylerfj24's Avatar
tylerfj24
So when you plug the phone in what happens with volume then? is it different from using BT?
Old Jul 16, 2019 | 08:16 PM
tylerfj24's Avatar
tylerfj24
Originally Posted by Babyboy
Tyler
I have an amp and I actually set the gain to work with the phone in the middle of the red volume line. I felt the SQ wasnt as bad this way and I still have good volume.. I am really interested now about plugging the phone in.
bigrobtemp
Audio Systems
May 27, 2017 08:46 AM
Drkknt
Audio Systems
26
May 24, 2016 06:53 PM
misterD
Audio Systems
Apr 19, 2015 06:42 PM
Jayhawker
Mar 5, 2015 07:12 AM
Ricks07
Oct 27, 2008 11:57 PM
