Cvaria's 2013 Wide Glide: Consolidated
Old 12-09-2015, 12:53 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
Default Cvaria's 2013 Wide Glide: Consolidated
I'm consolidating my nonsense into one thread-and from here on out only posting upgrades and bs in this thread. " 'cos I'm ****ing stupid"
Current Status: passed away
Was:
Scouting:
looking at dynas. few ?s
Purchase:
Just Pissed off 90% of my local dealership, because i'm stupid
Death:
https://www.hdforums.com/forum/dyna-...l#post15294030
Rebirth:
https://www.hdforums.com/forum/dyna-...l#post15331897
Alarm install:
Alarm Install?
LED Lighting:
Stage 1---
Bushing upgrade:
bushings... GTFOH!
Tank Lift 2":
DK 2" tank lift installed
Oil Cooler nonsense:
Oil Cooler Questions.
Mid's (-):
Mounting mid Pegs... Hole Fillers/Guards?
Accent lights (-):
accent led reccomendations
Chrome buttons :
Added Chrome handle bar button covers
Chrome lower belt guard:
Added chrome lower belt guard
Rear axle nut covers :
Rear axle nut covers ($17 on fleebay used) and my maryland plate showed up
Ditched the Cow Bell:
no more cowbell
Added pretty bits + alarm/siren installed and activated:
added pretty bits and had alarm/siren installed and activated
Brakes:
Tire rubbish:
https://www.hdforums.com/forum/dyna-...nt-skinny.html
Fatality!
Old 12-09-2015, 10:06 PM
cvaria's Avatar
cvaria
cvaria is offline
Default Added Mid Mounts and More Cushion Pegs
finished mounting mids
referring to the sevice book
pulled the plugs out with wine cork tool.... yes.. a wine cork tool<br/><br/>thank you forum
nasty under those plugs
anti seize, bolts p/n: 43214, and lock washers p/n: 7045
right mount is on, torqued to 35ft-lbs<br/><br/>peg on p/n: 91821-85<br/><br/>right done
pulled the plugs out with wine cork tool, again
9/16 socket. 9/16 wrench.<br/><br/>spring washer for peg mounting p/n: 250912-72<br/><br/>hex? locktite
left mount is on, torqued to 35ft-lbs
left done
done for now. mulling over the value of moving the controls
Old 12-11-2015, 02:15 PM
cvaria's Avatar
cvaria
cvaria is offline
Default added extended turn signal buttons. hd p/n: 71500178
Old 12-25-2015, 11:21 AM
cvaria's Avatar
cvaria
cvaria is offline
Default Magnum Chrome Spark Plug Wires and HD Chrome Electric Panel Trim
Silly Pretty Bits
Old 12-25-2015, 04:50 PM
Maxxsmart's Avatar
Maxxsmart
Maxxsmart is offline
Lookin good!
I assume that electrical panel chrome piece just sticks on like the reflectors or the forks / rear fender did?
Are those clutch cable clamps the Drag Specialties? If so, how's the fit & finish? I see several options from other brands, but wasn't sure how well the DS version were made. I guess the billet version of any of the manufactures is the way to go.
Old 12-25-2015, 06:37 PM
cvaria's Avatar
cvaria
cvaria is offline
Originally Posted by Maxxsmart
Lookin good!
yes sir, drag specialties:
https://www.hdforums.com/forum/dyna-...l#post14670003
they are great. i had a bad run with drag prior but these are great. cheap too @ $12
Yes, the trim went on with some super tape that was already on the part, it left a gap up front. i filled that with tacky glue. the glue dries clear.
Old 01-06-2016, 08:24 PM
cvaria's Avatar
cvaria
cvaria is offline
Default Removed Passenger Pegs
from thread:
https://www.hdforums.com/forum/dyna-...l#post14721630
i love HDForums! worth the $. wobble extensions and 1/4 bits
there was an incident with the t30 bolt (made of butter) holding on the upper belt guard. had to drill the head off. will swing by ace tomorrow and get a hex replacement.
Old 01-07-2016, 01:02 PM
Lotaluck's Avatar
Lotaluck
Lotaluck is offline
Allways read this thread when it pops up, great idea, and thanks for sharing. Like how you making your bike your own and not afraid to do a little wrenching.
Old 01-07-2016, 05:25 PM
cvaria's Avatar
cvaria
cvaria is offline
Thanks. wrenching is part of the fun, until you strip something
Old 01-07-2016, 05:43 PM
cvaria's Avatar
cvaria
cvaria is offline
Replaced the torx30 bolts with 5/16-18 hex bolts:
5/16-18 1"
5/16-18 1 1/2"
Quick Reply: Cvaria's 2013 Wide Glide: Consolidated
