Feedback on Attitude Adjuster
Old 04-08-2016, 08:14 AM
newdyna's Avatar
newdyna
newdyna is offline
Default Feedback on Attitude Adjuster
Just finished the Baker install with a couple surprising things. First is that some here were correct in that the two main parts will fit under the chain w/o removal of the comp. I did want to look for lack of lube or rust, and add some grease, but from external, all looks good. Note that the early comps were lubed externally with a grease gun??? My chain was dog tight...too much so for my experience with chains. Also with about 11k on the clock the nylon wear block was like new....hope this is also true when I check the cam chain tensioners later. In this harsh environment, I am using Amsoil....see their ASTM tests with comparos to others. As a note, when I was checking the comp bolt for torque, I notice that the spring will wind up. I wonder whether anyone has thought to develop a method to check spring tension using torque. This because some comp failures are due to spring failures? With the aluminum sprocket block tool in place, when you torque the bolt, the spring collapses and forces the shaft extension and crank to move, sprocket stays still. Should be a correlation between torque and movement.
Old 04-08-2016, 08:27 AM
archergodwin's Avatar
archergodwin
archergodwin is offline
If you're still using the old style oem comp, it's a weak pos.
As a side note, that over tight primary... can cause fractures in the clutch hub splines, on the inside next to the IPB... a larger than normal amount of bikes have those splines fractured about 3/8 to 1/2 from the outside in.
Found that on mine last year when replacing my alternator... installed a new hub, and a Hayden tensioner... got that stock ratcheting pos out of there.
Old 04-11-2016, 09:32 PM
newdyna's Avatar
newdyna
newdyna is offline
Good points Archer....so far, no metal on the magnet so I am hoping to spot any comp problems that may begin before they get bad. Noise might begin ahead of metal shredding, but will try to stay ahead of that one, thanks.
Old 04-12-2016, 08:17 AM
archergodwin
My stock comp went bad, you could hear it when I started the bike... it would go the end of travel and smack the stops.. sounded like someone with a small ball peen hammer smacking the primary case every time I started it... ... I installed the SE comp.. no issues..
Old 04-12-2016, 08:38 AM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
I hope the Hayden works out for you but for me it made my chain so tight I could barely move my chain up or down 1/8" using all my strength - Baker Attittude Adjuster in now...
rIsK
05-17-2017 09:04 PM
ElectraJim
12-01-2016 06:58 PM
slyedog
Engine Mechanical Topics
10-25-2016 05:07 PM
MrSunset
11
09-26-2012 08:57 PM
tazmandevil
06-20-2008 06:34 AM
Quick Reply: Feedback on Attitude Adjuster
