tank lift problem
Old 05-18-2007, 11:20 AM
johnnychum's Avatar
johnnychum
johnnychum is offline
Default tank lift problem
I tried to install my tank lift and I ran into a problem, the clip which holds a tube like hose that runs into a L-shaped rubber piece that goes into the tank was not long enough, is this a problem anybody ran into or am I the firstclown who can't do a simple job like this?
Old 05-18-2007, 11:27 AM
Bassman's Avatar
Bassman
Bassman is offline
Default RE: tank lift problem
Are you talking about the fuel crossover hose? If so, go to your local auto parts store and get a longer piece of hose.
One of these days, I am going to switch mine out to braided hose.
Old 05-18-2007, 11:32 AM
johnnychum's Avatar
johnnychum
I got the tank lift from chopper style and it came with two additional hoses I guess these could be one of them, but the thing is I have heard that when you do a 2" lift you don't need to change anything exept the bolts.
Old 05-18-2007, 11:39 AM
Psycho's Avatar
Psycho
Psycho is offline
I think you're talking about the vent line. Comes down the left side of the frame in front of the tank then turns and goes under the tank towards the rear of the bike. Has a little maybe half inch canister looking thing in line in front of the tank, which is zip tied to the frame.
If this is what you're talking about, you can either put a longer piece of vent tube from the little canister to the tank, or you can just cut the zip tie so that it can move up a little with the tank, and just leave it. It wont go anywhere.
I just cut the zip tie on mine.
TOMMAY's Avatar
TOMMAY
TOMMAY is offline
Think you're talking about the vent hose that goes up under the console. I had to buy a longer piece of hose when I did mine. Best I can remember the hose is clipped to the frame and you can leave the clip loose to gain a little length but it may not be enough.
Good Luck
Tom
Old 05-18-2007, 11:58 AM
johnnychum's Avatar
johnnychum
You guys say I can leave that hose loose and nothing happens, that was simple... Thanks brothers.
Old 05-18-2007, 01:45 PM
deeblues's Avatar
deeblues
deeblues is offline
Yeah I had that problem ....it's a 7/32 line that goes in the tank area with a check valve looking part on it
I just went to my local part store and got more line....
Easy fix....
[IMG]local://upfiles/23685/2D1EA4979F4946C59F4D5C225DFD988D.jpg[/IMG]
[IMG]local://upfiles/23685/E4932A2F06E44E3997173081830CA3F0.jpg[/IMG]
Old 05-18-2007, 03:48 PM
rocklayer2's Avatar
rocklayer2
rocklayer2 is offline
I also just cut the tye and let the vent tube hang and have no problems.
Old 05-18-2007, 04:38 PM
DiabloBlanco's Avatar
DiabloBlanco
DiabloBlanco is offline
I had the same problem on my 05 Super just left it to hang never had a problem with it.
Old 05-18-2007, 05:42 PM
007dyna's Avatar
007dyna
007dyna is offline
Just cut tie strap on neck. It's not going anywhere.
when I first lifted, my line came off and i had to unscrew my whole dash to put it back on. So i polished my filler cap while it was off.
then installed lift, snipped line, bingo. simple. done
Bagger_Vance
01-05-2020 11:30 PM
Ganooch
07-11-2010 08:04 AM
bigcwilli
09-15-2009 02:59 AM
nkauf21
11-04-2007 10:53 AM
wiscdyna
07-01-2007 10:58 PM
Quick Reply: tank lift problem
