Fluid leaking out clutch cable adjuster? Help!!!
Old 08-07-2013, 05:27 PM
Robbie13's Avatar
Robbie13
Robbie13 is offline
LOSER
Isn't there a forum member named dirtdobber? Did he do it?
  #32
Old 10-13-2013, 06:33 PM
GinsengSullivan's Avatar
GinsengSullivan
GinsengSullivan is offline
Originally Posted by PhantomGoat
My bike has been sitting in the driveway for a month and just today I found this thread and fixed the bike in 5 minutes with no tools....there was dirt and remains of some sort of bug in my tranny vent tube. I know this thread is years old, but I want to say THANK YOU THANK YOU THANK YOU...bike isn't leaking any more and I get to ride it every day now!!
Don't worry bout being an old thread, if it helps pass it on... I had the exact problem and found this thread. Was a damn "stink" bug stuck in the vent tube... Thanks guys!
  #33
Old 05-23-2015, 10:26 PM
shineola's Avatar
shineola
shineola is offline
Old post ........ But it just possibly solved my trans leak. It would be good to check anyway as no tools needed .... Took 5 min to clean
  #34
Old 05-24-2015, 03:06 PM
Dex07FXD's Avatar
Dex07FXD
Dex07FXD is offline
While you are checking the vent tube hose, go a little further and check the hose fitting that screws into the trans cover. Gently try to put something small through the fitting bore. If it is not wide open, remove, clean out debris and reinstall fitting. Dirtdobbers had packed not only my vent tube,but this fitting also.
  #35
Old 05-26-2015, 08:54 PM
bremsstrahlung's Avatar
bremsstrahlung
bremsstrahlung is offline
I'll add another possibility to tranny fluid on the clutch cable for you. The fabric cover on my clutch cable was always had oil on it. I just figured it was persisting from the inevitable spillage from getting the oil filter off and was impossible to get it 100% clean. I figured I'd just take the fabric cover off entirely.
I disconnected the cable from the lever and cut the fabric sheath off. Turns out that the clutch cable had been rubbing on the underside of the frame forever and had worn a tiny hole in the cable sheathing. Never wore a hole in the fabric cover, just the cable sheathing underneath. The tranny fluid in the cable was weeping out and being carried down through the capillary action of the fabric cover. I would have never been able to see it if I hadn't cut off the fabric cover.
  #36
Old 10-24-2015, 09:57 AM
customstrtbob14's Avatar
customstrtbob14
customstrtbob14 is offline
Stage IV
It's an easy fix common problem there is an o-ring for the cable going into the trans replace it ull be good I had to do same. Don't over tighten it finger tight till the new o ring seats then a 1/4 to a half of turn with a wrench
  #37
Old 03-13-2016, 06:43 PM
Iculukn2's Avatar
Iculukn2
Iculukn2 is offline
1st Gear
All, I'm checked and my vent line appears to be clear. I pushed a weedeater string into it out of frustration. but to be sure, if I tug hard enough on the vent line, I assume it just pops off, nothing but a solid pull right?
Once I have it removed, installing it back, is just a push back on?
If that is not the issues, I'll go replace the clutch cable O-ring. But what would push (pressure) fluid up into the clutch adjust on the frame.
-Donald
2009 FXDF Fat Bob
  #38
Old 03-13-2016, 07:41 PM
DJY's Avatar
DJY
DJY is offline
pretty sure you have to take transmission top cover off to install vent tube.
skirtbum
06-26-2010 05:45 PM
trampsinger
05-08-2009 04:25 PM
YellowHawk
12-16-2007 05:40 PM
bg5377
14
11-11-2007 09:05 AM
Sally88
09-22-2006 11:14 PM
Quick Reply: Fluid leaking out clutch cable adjuster? Help!!!
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
