ATT: Low Riders-Tips for Riser/Bar changes
I thought I'd share my experiences on this topic as it is a PAIN to change out the risers/Bars on an FXDL as the indicator lights are in the clamp.
I bought a set of 6.5" Drag Specialties pullback risers for my bike and installed them, but as you may or may not know the stock handlebar clamp WILL NOT fit with aftermarket risers. After much thought on what to do about this I finally decided to order a handlebar clamp from the 99-03 Sportster Custom as it has a built in Indicator light slot and fits aftermarket risers.
After the install was complete all that was left to do was to hide the bottom side of the indicator light module. This was done by taking apart my stock indicator module "cover" and removing the holder for it. Once I did that I simply Glued it onto my Module where it meets the handlebar clamp. This was a PAIN as well but she turned out great. I also added a 3" tank lift (LOVEIT!!!!) and lastly I added another 2" of riser lift by installing 2 SOCKETS (yes...sockets) to the bottom of the risers with longer bolts.
There you have it, an FXDL with aftermarket 32" Buffalo Drag Bars, 8.5" Pullback risers and 3" tank lift.
Thought this advise would come in handy to some of ya'z!!!
Pics Below (ya...that's SNOW!!! CRUD!!!)
[QUOTE=creekhed1;4131258]I thought I'd share my experiences on this topic as it is a PAIN to change out the risers/Bars on an FXDL as the indicator lights are in the clamp.
QUOTE]
you do anything to the stock cables? brake line? wiring?
QUOTE]
