Clutch Lever Releasing Too High???
Old 09-28-2010, 06:20 PM
lhgdale's Avatar
lhgdale
lhgdale is offline
Default Clutch Lever Releasing Too High???
Hello, I recently adjusted the clutch on my 10 wide glide per the service manual while I was changing my primary fluid. Following the service manual my clutch releases really high in the lever action. I personally like mine to release mid way in the lever release. I was able to get it pretty close to my liking by adding a little slack to the clutch cable.
My question is, is there anyway to get the clutch in the sweet spot without having slack in the cable? Or should I just get used to it releasing higher?
Thanks for the info and help.
Old 09-28-2010, 06:26 PM
pcbunn's Avatar
pcbunn
pcbunn is offline
I did the same with mine, added about 1/8 to 3/16th of slack so it engages just prior to midway. Clutch feels fully engaged and disengages enough as far as I'm concerned to not wear the plates. I hated the way the service manual left the engagement so I just changed it like you did.
Old 09-28-2010, 06:31 PM
2TallGlider's Avatar
2TallGlider
2TallGlider is offline
The manual gives you a range you can use to back out the adjusting bolt once you have reached the initial friction point (I think it's a half to a full turn out). Try changing how much you back out within that range and see if that helps.
Old 09-28-2010, 06:40 PM
lhgdale's Avatar
lhgdale
lhgdale is offline
Ok, I will try that next time i have the primary cover off. I'm glad to hear I am not the only. Thanks
Would I loosen the nut more or less the get the clutch to release midway on the lever?
Old 09-28-2010, 09:56 PM
blacknsilver's Avatar
blacknsilver
blacknsilver is offline
You back it out a half turn after contact. Make sure you adjust while it is not hot also. Here is a good video also.
http://www.ehow.com/video_2330184_ad...utch-pack.html
http://www.ehow.com/video_2330185_ad...tch-cable.html
Old 09-29-2010, 03:49 PM
lhgdale's Avatar
lhgdale
lhgdale is offline
Thanks blacknsilver, I used the service manual and those videos to adjust my clutch. If it takes a little slack in the cable to get it to release where I want, I guess I'll just live with it. Thanks
Old 09-30-2010, 08:33 AM
Grendel4's Avatar
Grendel4
Grendel4 is offline
My concern would be that the clutch adjustment inside the primary is not correct. Just because the clutch lever is all the way out doesn't mean the clutch pak is engaging correctly or fully.
When I did my fluid changes I thought, maybe, I should have adjusted the actual clutch because it felt to me like I wasn't getting enough initial engagement. I rode it for a few miles and it came back. Plenty of lever now.
My clutch will 'catch' slightly about a half to 3/4 inch from the grip, then it is fully engaged about a half to 3/4 inch from full release.
I'd check it and if it's not 'catching' at about one-third release or before, I'd go ahead and adjust the clutch pak.
My measurements are probably off. I've been riding and driving standard transmissions for a long, long time and I can tell when a clutch isn't engaging properly. I'm sure you can too. If it ain't right, adjust it.
Clutches slip. They slip ALL the time. Not just on start up or between shifts. I'm talking ALL, 100% of the time. The thing is, how MUCH are they slipping. Too much is bad for the clutch. Too little is bad for the rest of the drivetrain. Especially the tranny.
Just my $.02 and just my opinion. Good luck.
Old 09-30-2010, 08:42 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
If you leave your clutch loose on the adjustment make sure you adjust it more frequently or you will wear it out faster. I do mine to the book so it fully engages/disengages and I don't have to adjust it much. But when it begins to feel a little drag when I take off from a stop I know it is time for primary oil & an adjustment.
HD4772
05-17-2013 10:20 PM
theindian
07-30-2012 04:45 AM
sdoomaha
07-09-2012 05:58 PM
jc15025
03-13-2012 04:12 PM
dan69co
06-02-2007 09:01 AM
Quick Reply: Clutch Lever Releasing Too High???
