Fuel quick disconnect line
I've got a fuel leak coming from my QD which only leaks when the fuel pump is on/bike is running. Instead of buying a new line or check valve I'd like to look at the o-rings, but I'm not sure how many there should be. I see one on the check valve (installed on the tank) but none on the fuel line, the male part of the connection. I recently had the tank off so the line was disconnected; so I'm thinking an o-ring was damaged.
Anyone have any good info on the o-rings?
Thanks for the reply. I believe that o-ring is sandwiched between the tank and check valve, not inside the check valve or QD. From what I've read HD doesn't sell just the o-ring(s), just the entire fuel line.
Notgrownup
27
09-10-2022 05:46 PM
