help with diagnostics CAL 09
Old 11-16-2011, 10:58 PM
jslum's Avatar
jslum
jslum is offline
Default help with diagnostics CAL 09
So My engine light was coming on for a second after I start my bike (99 fxdx) then shutting off. I go to check the codes- key in, hold odo reset, switch to ignition, release, and.... no speedo cycle, all lights dont come on. Immediately reads d01CLr and goes all the way through to d10CLr then to CAL 09 then starts all over again no matter how long I hold the odo reset in for. What does CAL 09 mean and what else is going on? thanks
Old 01-17-2015, 01:47 PM
Texas_Rider11B's Avatar
Texas_Rider11B
Texas_Rider11B is offline
Please tell me you figured this out, I'm having the same issue but add the speedo and odometer doesn't work when I throttle up but it does when I pull the clutch and off throttle.
Old 09-22-2015, 10:01 AM
Travis Mosley's Avatar
Travis Mosley
Travis Mosley is offline
Stage II
Default 2000 FXDX speedometer trouble
I had the exact same problem no codes in the system. Harley Davidson shop said replace speed sensor, no help then replace speedometer $250 + shop fee. I said no went to YouTube (lol last resort should be first) checked charging system, was fine at idle but on rev was going to 18+vdc. Ordered a rebuilt voltage regulator for $45.99 free shipping. Two days latter it arrived installed it now all is good.
Old 09-22-2015, 12:05 PM
Travis Mosley
Stage II
CAL09 is the calibration setting for the speedometer, how to change the setting is beyond my pay grade. Mine is set to CAL 03 and at 50 mph the speedo reads 52.
harleydogs22
Electrical/Lighting/Alarm
06-18-2019 10:48 AM
RosevilleRiding
06-02-2018 08:47 PM
ajames01r
05-22-2018 07:39 PM
Texas_Rider11B
01-16-2015 10:55 PM
buddyman47
10-09-2013 07:09 PM
Quick Reply: help with diagnostics CAL 09
