FL-Xied-10 and check enging light is on
Old 07-31-2012, 06:45 AM
Ron C's Avatar
Ron C
Ron C is offline
Default FL-Xied-10 and check enging light is on
I have a 2012 super glide and I installed the FL-Xied-10 on my bike.
After installing it I started the bike with no problems.
The check engine light is on all the time.
Did I do something wrong installing it?
The bike runs great so I have no clue whats going on.
Let me know what you think.
Thanks for looking.
Old 07-31-2012, 07:15 AM
Sharkman73's Avatar
Sharkman73
Sharkman73 is offline
Possibly the ground wire on one of the FL-XiEDs is not grounded properly?
That would be the first thing I would check.
Old 07-31-2012, 07:17 AM
RAWHIDE07's Avatar
RAWHIDE07
RAWHIDE07 is offline
Received 37,239 Likes on 12,891 Posts
I would contact Nightrider and get their input.
Old 07-31-2012, 07:40 AM
sgmfiser's Avatar
sgmfiser
sgmfiser is offline
Don't worry about it. That is normal with xieds. The engine monitor is picking up the extra fuel being injected and being a computer, it just knows something is wrong. The monitor light goes out as you increase riding speed and comes back on at idle. No problem. Isn't it great having a computer that knows more than you and insists on telling you all the time?? I pay no attention to any light except the oil pressure and the charging lights. In the wind.
Pops
Old 07-31-2012, 08:11 AM
Chief21's Avatar
Chief21
Chief21 is offline
I have them on mine and have never had the C.E.L. come on. I would do like Sharkman said, check and make sure you have good grounds on both of them. I was also thinking there was something in the literature about bad or no grounds and the C.E.L. .
Old 07-31-2012, 08:35 AM
ynots's Avatar
ynots
ynots is offline
Heres some info on codes directly from nightrider.com
Old 07-31-2012, 10:19 AM
Foxster's Avatar
Foxster
Foxster is offline
I think they go too far with the bias that they use on the Xieds. To get down to the AFR they do they need to take the bias to over 800mV. This is beyond the recommended limits for narrowband O2 sensors, especially as they get older. This shifts the sensors into an operating region they are not sensitive in.
This means that not only aren't the sensors going to be working very well, it also causes the ECU to throw codes because it thinks the sensors are faulty.
I think a better option is to use their FL-VIED-10, which is their variable version. Then not set them to the max setting.
Old 07-31-2012, 09:03 PM
Ron C's Avatar
Ron C
Ron C is offline
Hi
Thanks for all the input.
I found the problem.
Was thinking about this morning and I remembered my buddy did not plug in one of the conections under the seat.
Fixed now.
Thanks all.
fchalker1981
06-13-2016 11:34 AM
wingshootin1275
11-24-2013 08:53 AM
Tuco069
01-26-2012 10:52 PM
lblankenship
05-10-2009 07:36 AM
Jordy806
09-09-2008 08:07 AM
Quick Reply: FL-Xied-10 and check enging light is on
