Check engine light
Old Nov 23, 2013 | 09:01 PM
wingshootin1275's Avatar
wingshootin1275
Default Check engine light
Just got back from a ride that had a few stops on it and I cant get to the dealer until Tues but I have a question. The engine light came on as I was riding down the road and stayed on for like 30 seconds and then went off. Stop at a local watering hole and when I got on the bike again and was rising the light stayed off. Stopped at another local place and on the way home the engine light came on again for roughly 30 seconds as I was riding down the road. Any ideas? 06 Street Glide fuel injected. Thanks
Old Nov 23, 2013 | 09:23 PM
gregfri's Avatar
gregfri
My engine light comes on when I get on the throttle hard. Seems to only happen after engine is warm, and light goes off after I return to normal driving. Have had dealer check it, says everything is ok. It did this most of last season, I have learned to ignore it as bike runs and performs as normal. This is on a 07 ultra
Old Nov 23, 2013 | 09:34 PM
wingshootin1275
My bike performs as it should and seems to be running very good as well. Ill have them check it just in case.
Old Nov 23, 2013 | 09:38 PM
dawg's Avatar
dawg
Check the codes yourself. Not hard. Will give you an idea of what it is. Might be just a lean code or something. Can clear it as well.
Old Nov 23, 2013 | 10:04 PM
streeteagle's Avatar
streeteagle
Old Nov 23, 2013 | 10:13 PM
QC's Avatar
QC
I had a similar issue that turned out to be the plug wires. Here is a link to checking the codes:
https://www.hdforums.com/forum/softa...odes-dtcs.html
Good luck!
Old Nov 23, 2013 | 10:32 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
If it's warranty, take it to the shop.
Old Nov 23, 2013 | 10:54 PM
bdtaylor1979's Avatar
bdtaylor1979
Originally Posted by streeteagle
X2. This will tell you how to check for codes.
Old Nov 23, 2013 | 11:48 PM
Def Mute's Avatar
Def Mute
Yep...
The engine light is there to tell you of some trouble which may be present, or historic. Meaning, that some problem has occurred recently, but may not be a continuous problem at this time. A present code should result in the engine light blinking about 8 times after a brief pause once the engine has been started. Historic codes may be indicated by the engine light for 50 on/off cycles of the ignition switch.
Check codes as stated above. Ignoring this warning may lead to further, or possibly more costly problems.
Old Nov 24, 2013 | 08:53 AM
wingshootin1275
Thanks for the info folks!
tacscoter
Apr 29, 2017 04:36 AM
Kyle C Kirk
Nov 9, 2015 02:13 PM
chizman
May 15, 2011 04:35 PM
gatorwalt
Jul 24, 2008 10:26 AM
Inforit
Jul 17, 2006 04:54 PM
