Need to change 18" apes to 12"
Im looking a buying a wide glide that already has 18" apes installed.....But the problem is, is that they are way too tall for my liking.
Is it an easy change back to 12"? Will I need to change out the brake and clutch cables? (Is that a relatively easy thing to do) And lastly, can I just hide the excess wiring under the tank?
Appreciate any insight. Thanks.
Not under the tank persay...in the backbone of the frame under the tank. Depending what year bike, there may be a small plastic cover on the bottom of the backbone at the neck (ya know, where your front end swivels left to right at the frame) above the front cylinder. That's the one closest to your front wheel. It may be snug in there as other wiring is stored there too.
