2000 Dyna Speedometer power loss
I lose total power to my speedo about 5 sec after starting engine. When key only 'ON' it works ok. I've checked all my wiring and connections and even tried another speedo...
The bizarre thing is that once bike is running and speedo fails, if I select either left or right signal switch, the odometer comes back live and the LCD display flashes on off in sequence with the signal lights!
I can drive 20 minutes with the failed speedo and needle stuck in position of power loss, then all restores normal for a while..then quits again later.
I've not yet changed the speed sensor on top of tranny, but only cleaned the swarf off the pickup sensor.
Just wondering if the speedo sensor would also give me this weird flashing of odometer with signal lights.
Bike is 100% stock and never apart...80k on it.
Whaddya think??
Jim
Whaddya think??
Jim
Whaddya think??
Jim
Whaddya think??
Jim
I'd probably start at the back of the speedo and work your way down the harness, then I'd start with the controls and do the same.
Best of luck.
Thanks Grumble,
So given the fact that the signal lights coincide with the flashing odometer, can I steer away from the speed sensor on tranny?
The vibrations when running most likely causes the break or shake...
I've replaced the speedometer harness already and have checked the control switch wiring too.
I'm convinced it's something in the front neck/tree area where all those harnesses live.
Pity the 2000 Dyna has main harnesses hidden in frame channel and deutsch plugs buried in frame....
Just a real pain in the A.
Jim
Jim
Thanks Grumble,
Jim
Jim
speedjunkie762
06-30-2011 05:53 PM
jcboof
03-19-2008 05:57 PM
