99 Superglide Speedo not working
Old Jun 29, 2011 | 02:33 PM
speedjunkie762's Avatar
speedjunkie762
Stage IV
Default 99 Superglide Speedo not working
Hey Everyone,
New here. Been checking and using info off this site for a while and finally signed up today. Thanks for all your help in the past. I have a 99 dyna superglide sport and the mph, back light, and miles are not working on speedo. When I turn the key on the engine light comes on for about 8 seconds then goes away. I also pulled the sensor out of the trans and cleaned that off. Any ideas?
Old Jun 29, 2011 | 05:36 PM
Little T's Avatar
Little T
Check on the back of the speedo for power and ground. The ground should have .5 or less ohms and I believe the orange and white wire carries power. If you have those then more than likely your gauge has gone bad. The speed sensor in the trans only sends a speed signal and has nothing to do with the backlighting to the speedo
Old Jun 29, 2011 | 06:29 PM
speedjunkie762
Stage IV
I just checked and yes the orange and white has 12v. Assuming ground to be the black wire it has 36.2ohms and changes with key on/off. Not sure I have the right wire. Do you know the color for the ground?
Old Jun 29, 2011 | 10:45 PM
Little T's Avatar
Little T
Usually black are you checking with the speedo plugged in or not?
Old Jun 30, 2011 | 08:30 AM
speedjunkie762
Stage IV
Not plugged in.
Old Jun 30, 2011 | 10:27 AM
Little T's Avatar
Little T
Doesn't have a very good connection I would try making a jumper wire for the black lead and connect it to ground directly and plug speedo in. Good connection = .5 ohms or less
Old Jun 30, 2011 | 05:53 PM
speedjunkie762
Stage IV
Just made the jumper wire direct to ground and still not working. Checked and had 12v across ground and orange wire so im thinking this speedo is shot.
jim70
Oct 4, 2016 07:16 AM
ChargingRhino
Jun 20, 2014 09:54 AM
jreichart
Dec 24, 2012 08:42 PM
jredd29
Sep 27, 2011 04:46 PM
jredd29
Custom Models
May 11, 2011 10:14 PM
