One more fork question
Old 06-27-2014, 09:55 PM
mikeyglide's Avatar
mikeyglide
mikeyglide is offline
Default One more fork question
2001 fxdwg
After filling the forks with oil does it matter if the front is off the ground when tightening the fork caps , or should it be on the ground with weight on the forks( slightly compressed by the weight of the bike)?
Old 06-27-2014, 10:15 PM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
Received 20,117 Likes on 10,260 Posts
What are you using to set your oil level or are you measuring it out? I believe the book says the forks should be all the way extended when filling, springs in. Once the oil is in you should actuate the forks several times to remove the air. That should answer your question.
Old 06-27-2014, 10:33 PM
mikeyglide's Avatar
mikeyglide
Measured it out
12 oz using a quality measuring cup the ex wife left here 5years ago when she left.
Now it's in the garage .
Put 12oz back in. That's what is spec'd.
Seems fine just wasn't sure if it matters up or down when tightening caps . Guess it doesn't
Old 06-28-2014, 05:45 AM
union53's Avatar
union53
union53 is offline
The forks should be extended. The volume of air does make a difference.
Old 06-28-2014, 06:10 AM
Galaxie500fb's Avatar
Galaxie500fb
Galaxie500fb is offline
off the ground
Old 06-28-2014, 06:45 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Jeff's 1st Harley is offline
Off the ground and extended forks.
Old 06-28-2014, 07:49 AM
mikeyglide's Avatar
mikeyglide
thanks
Old 06-28-2014, 07:57 AM
ynots's Avatar
ynots
ynots is offline
If the tubes are not fully extended your going to be really hard presses (pun intended) to get the caps back on.
Old 06-29-2014, 08:37 AM
IronUA's Avatar
IronUA
IronUA is offline
Yep took them off once with the bike on the ground and the cap shot out like crazy haha
jon loder
04-06-2017 10:04 AM
scorpion65
02-22-2013 04:27 PM
shrini23
10-31-2009 06:41 AM
BrentsterS
08-10-2009 08:46 PM
papamonkey
14
11-07-2005 07:57 PM
Quick Reply: One more fork question
