TMAN or FM 555 cams
TMAN or FM 555 cams
Currently run a se204 and se 1.725 rocker arms. Did a search with out real answers.
So what about one of the 555 cams with the high ratio rocker arms since i already have them. the lift would be around .589 would the se valve spring rated to .585 be ok with this set-up? Do you think it would run good I have se cnc heads willing to send heads out for work.
I imagine that you are refering to a Wood 555(not fm).
But that said, the 204 with those rockers set at the proper compression, and headwork WILL run very well indeed, and really could not try to put my sales-man hat on here to try to sell a client either one of those cams vs your current set up.
Want a big jump in overall power, step up to a Wood 8, 9B, S&S .585, or .625, Crane 296-2, etc.(which we have great expierience with all of those, and more) and set it up accordingly.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Hi,
I would put the se259e that came in the kit(if you got original kit), if havent got them you will get them for a song on ebay, a lot of riders like them
A rider here in Aus put the woods555 in same spec as yout bike and results the same as with the se cam, it didnt go WOW theres 10HP and 10Tq
Thanks
Mirrmu
Thanks
Mirrmu
The SE CNC heads are not bad out of the box but any factory head could benefit from some work. I would send the heads out for work and build around one of the two S&S cams Scott suggested or two of my favorites the TMan 577 or 590; just pick the cam first and have the head porter work around that cam. Any of those cam choices will be better than any SE cam.
Having said that, your setup is not bad; JMHO but the SE204 is an often maligned and underrated cam. As SE cams go, the 204 on stilts with the right compression is probably the best SE/OEM setup. A couple of years back a buddy and I built a 103" motor around the SE204 and 1.7 rockers with a set of worked heads and the motor made 113TQ/106HP (don't recall the exact numbers but those are pretty close); pulled from the bottom to the rev limiter and had a nasty idle. It was an experiment that worked. You might just need to work the heads for better flow and a bit more compression. Just have to be careful with the compression with the 204; it can get tricky to tune and prone to detonation when CCP gets much above 190psi; might get away with 195psi but I would keep it between 185-190psi and use compression releases.
They effectively create another .030" lift, and according to Crane Cams create another 2-3 degrees duration.
Low-cost bump on a cam(not all cams really like this) when looking for more.
Scott
Ignorance pardoned! if starting from scratch, selecting a cam with the desired lift would be preferred but if one has a cam, rockers are cheaper than new cams and easier to install;see Scott's reply. In the case of the example I posted, it was an experiment that worked; the 204 cams like the added lift and dyno results bear that out.
