Andrews 37H or 57H cams for my SE 2008 Springer
I've read so much lately about cams, fck...
Anyway, looking at the 37H cams on my SE 110B 2008 Springer.
V&H Big Shots ( baffled ), SE heavy breather.
After maybe another 8-10 hp and 8-10 tq, currently have 97 hp and 114 tq.
Would these figures be around the mark?
Looking at more punch at 2500-5500 range.
What pro/cons in skimming 030"-040" off the heads, good idea?
Any other cams? Andrews 57H?
Not looking at changing lifters or push rods etc.
thanks boys
thanks boys
The 57 is the high-lift version of the 37, with tweaked exhaust timing.
It'll out-produce the 37.
Just finished another 107" 2 days ago with that cam, and an S/E 58 mm/our Stage II Plus Heads.
It's snappy.
Scott
It's snappy.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I think I would be looking to port those heads and deck as required to build around a higher lift cam like the TW60, TMan 590, SS 625, etc. but that's just me.
Yes they are! Since I put a set in mine due to Scott's advice, I have done 3 more bikes after they ride mine. They are never a bad choice for a cam only swap!
I agree with DJL also, with 110 CI to play with port heads and set compression for some larger cams.
