Carb Cough or Misfire
Old 12-06-2014, 11:54 AM
Tony_N's Avatar
Tony_N
Tony_N is offline
Originally Posted by johnjzjz
right side is the carb side - in my shop we swap out all 4 allens - the right side we use 12 point bolts that have 5 /16 heads on them so we can use a 1/4 inch drive 5 /16 universal swivel socket to tighten them -- it make it a snap to repair in the future
1/2 wrench left side - 5 /16 - 1/4 inch drive swivel right side
Thanks John. That helps.
Old 12-06-2014, 12:42 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
Cars and bikes are the same...... right and left are always determined by as it is when you are driving/riding the vehicle.
Old 12-10-2014, 08:53 PM
Tony_N's Avatar
Tony_N
Tony_N is offline
I finally got a chance to get back into it today before heading to work tonight. The pics below are the new seals that I put in alst week and were still leaking. I went to my Indy Pro Twin Performance and picked up a set of Cometic intake gaskets. Kevin also planed the intake flanges for me so they were flat. Put it all back together and also replaced the carb spigot gasket.
Originally Posted by nhrider1
Take another look at the accelerator pump.
Jetting sounds about right and the plugs don't look bad.
The problem is either with the needle jet or accelerator pump, and that needle should be good.
Look at the accelerator pump either it's blocked or has a bad diaphragm.
I know the diaphragm was recently replaced, but check it again.
The accelerator pump was working fine as shown in the pic below. I still replaced the spring and accelerator pump diaphragm while I was in there.
John thanks for the tip on the 1/4 inch drive swivel for the 5/16 12 point, it worked really well.
Old 12-10-2014, 09:23 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
the blue seals are a china replacement i never use them we just throw them away - OEM or james are good quality
Old 12-10-2014, 10:00 PM
Tony_N's Avatar
Tony_N
Tony_N is offline
Those blue seals were James silicone gaskets.
Old 12-11-2014, 05:49 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
the china stuff i have seen are blue someone should tell james they are color copying a product they make
Old 12-18-2014, 03:31 PM
Johneblast's Avatar
Johneblast
Johneblast is offline
You did say CV. Check the boot to the manifold. This is a problem with the CV and the main reason I switched to a Super E. The Super E BOLTS to the manifold, not slipped into a boot. That boot expands and retracts sucking air. I had my CV shut me done cold in the diamond lane with my daughter on back in the peak rush hour. That was the straw that broke the CV back for me. Sacrifice the fuel mileage and get a S&S!
Old 12-19-2014, 02:54 PM
Tony_N's Avatar
Tony_N
Tony_N is offline
Thanks... I replaced the boot when I replaced the intake gaskets. 180 miles ride this past weekend in the GA mountains and it's running great now.
Efrain Jensen (04-01-2020)
marko69
04-01-2020 02:53 PM
Superduper
EVO
14
03-28-2019 04:50 PM
lmz5150
EVO
29
05-12-2017 02:41 PM
CSS_FXD
09-23-2011 09:34 PM
jaysledge
Engine Mechanical Topics
08-12-2011 11:54 PM
Quick Reply: Carb Cough or Misfire
