oil light help
oil light help
i just changed the oil on my 1996 dyna and now when i come to a stop the oil light comes on and turns off as soon as i take off. did i do something wrong? bike has 36k miles if that matters. this is my first time doing an oil change on a harley but have done many jap bikes and car oil changes.
Received 4,317 Likes
No it doesn't and whoever told you to has very little knowledge for an EVO's oil system.
The oil filter is the last thing the oil goes through before it gets back to the oil tank.
What rpm is your idle?
If it is less than 1k rpms then up your idle.
If that didn't help try running some straight 60 weight.
If that doesn't do it try some 70 weight.
Same problem oil light new M8
I had the same problem with mine right before delivery was the pressure relief valve stuck open. So at rpm below 1200 the light would illuminate. Above that would extinguish. They replace the oil pump and while they were in ther I had them install stage 2 tork cam. No labor charge. Bike is running fantastic beat problem you could have. Inquire about the cam. Should be no labor.
Received 14,175 Likes
This thread is actually older than your bike. 2015 is the year of this thread
glidein wide (09-26-2016)
