timing
Old 07-15-2011, 02:22 PM
harley7316's Avatar
harley7316
harley7316 is offline
Default timing
Hi was wondering if someone can give me some advice.I have 1340 evo se heads,ignition,coil 10.5 to 1 compression and se57 cam was wondering when i set the timing do i still go 35 degrees full advance?Also if i want to retard timing a few degrees when you lossen off the studs and place a screw drive in the notch to adjust which way do you turn the screw driver to retard counter clockwise?Thanks for the help
Old 07-15-2011, 04:18 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Stay with original timing or get an aftermarket module.
Retard ign by turning plate counter clockwise.
98hotrodfatboy
08-22-2018 01:48 PM
wscott62893
06-27-2014 11:59 PM
harley7316
EVO
08-04-2011 05:19 PM
meatball654
05-26-2006 05:38 PM
UK_74XLCH
Classic
07-29-2005 07:54 AM
Quick Reply: timing
