Küryakyn Iso Grip sticking.
Those who have the Iso Grips, are you have a little sticking when turning the throttle? Not the smooth roll on as with the stock, but just a little stick. And is there more up and down movement at the top of the grip? Or the whole grip have movement? Called Kuryakyn and asked if they have hear of any. Naturally they said no. I asked a few riders who had them and they said they did notice a little sticking. Have you?
As suggested above, lube the cables and grip. I have had 4 sets of Iso grips and notice on the ones I have now,"12 Deluxe,the quality doesn't seem quite as good as previous grips.More slop in the throttle sleeve. I still like 'em though. Maybe it's my imagination.I'd like to hear if others feel this way.
2014 Electra Glides do not have cables. It an electronic throttle. I will try a little grease on the inside of the grip. I found a little rub marks on the top outer and looking into the grip body another rub mark. If the problem is with the grips, Kuryakyn should be made aware of the problem. It doesn't cause any problem it's just a minor pain in the a$$.
having tbw, whenever I have seen 'sticking' problems, it has been because whoever installed them just jammed them on as far as they would go. can't do that, they will bind on the end. loosen up the clamshell and slide it out away from your handlebar about 1/16''. it will loosen up nicely and still engage the gear on the tbw.
