Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I changed my ignition switch because I lost the key. Installed and put coils back on. When I go to start it turns over , runs for 5 seconds and backfires and shuts off . any one have any ideas whats wrong ? Please
EFI or Carb? Did you check for codes? Diagnosing a problem over the internet isn't always easy, but you'll get more help if you tell us what you're riding. Year, model, mileage, mods, etc.
If you moved it I would check to see if you pinched a wire or loosened a connection. Most likely something simple. If it worked before and doesn't now. Double check everything. Switch could be bad but not usually
