ignition problem
Old Dec 6, 2011 | 08:45 AM
solo24's Avatar
solo24
Stage III
Default ignition problem
So.... my ignition is acting up. It won't start unless I jiggle the key in the ignition and it won't stay running. Seems like a wiring problem. Last time I rode it she was fine but I did let it idle a few weeks back for 10 minutes just to run some fuel though the injectors as I don't ride it much.
It's an 08 Dyna LowRider with 3000 miles. Is there a way to pull the ignition switch out to look at the wire harness? I tried to get a look though the frame but nothing is visible.
Thanks for any input
Old Dec 6, 2011 | 10:29 AM
Aborigen2's Avatar
Aborigen2
Unfortunately, if you have to jiggle the key to make contact it sounds more like Ignition Switch problem, not a wiring problem.
If you turn Ignition Key ON and reach behind the switch and wiggle the wires and get intermittent contact then it would be a wiring problem.
Old Dec 6, 2011 | 12:41 PM
JohnFlorida's Avatar
JohnFlorida
switches are cheap and easy to replace. I think BK rider has them for about $20
Old Dec 10, 2011 | 06:32 PM
solo24's Avatar
solo24
Stage III
Thanks for the input. I appreciate it.
Scott
Finn696
Sep 3, 2016 10:00 AM
crawfordcl
Sep 15, 2010 10:52 AM
crawfordcl
Sep 11, 2010 08:21 PM
quadzila1
May 24, 2010 08:50 AM
extoyota
Jun 25, 2009 06:47 AM
