P0505 - High Idle on 2007 FLHTC - Resolution
Old 04-15-2010, 03:12 PM
pjtj2000's Avatar
pjtj2000
pjtj2000 is offline
6th Gear
Thumbs up P0505 - High Idle on 2007 FLHTC - Resolution
Symptom - Ran a few errands and when I got home my bike was idling around 1500 RPM's
I didn't think much about it. Later that day I went to a friends house on the way there I stopped for gas, when I was coming to the light the idle was around 2k now. I was like WTF?
By the time I got to my friends house the bike was idling at 5500, and my check engine light was on. I checked the error code and I was getting a P0505 code.
Solution - I search this forum and found a similar issue and fix. On the bottom front of the intake there is a screw that is used to adjust the throttle. That screw had worked it's way out and was holding my throttle open. I put some blue lock-tite on her and tighten it back up. Problem resolved.
Thanks everyone who has posted on this
Old 04-15-2010, 06:41 PM
Snydcat's Avatar
Snydcat
Snydcat is offline
i had the same thing happen to my 2007 Street Bob today !!
Old 04-16-2010, 09:04 AM
Old Gunny's Avatar
Old Gunny
Old Gunny is offline
Thats a good fix.
I had that and one of the injectors was leaking thru.
Old 09-03-2013, 08:40 PM
Wardo8379's Avatar
Wardo8379
Wardo8379 is offline
5th Gear
Default Having same idle issue
Got on my 07 flhx today and when I came to a stop it was idling at 3000 rpm......uuuuugggghhhhh
I work on cars and have just started doing basic maintence on my Harley....but I have know Idea where this "screw" yall are referring to is located to you have a pic of where it is at? My bike is Fuel Injected...fyi
arejay86
07-13-2013 12:19 PM
Rickey
10-16-2012 05:56 AM
SSN711
11-12-2011 08:31 AM
Wonkaboy
09-17-2011 02:18 AM
drspencer
08-12-2011 08:44 PM
Quick Reply: P0505 - High Idle on 2007 FLHTC - Resolution
