Power Vision Information Thread
#8812
Hello
Request from Belgium
Seeking a stock map of a 2014-2015 touring 103TC, domestic, model.
I want to compare the stock domestic map, with the stock map of my FLHTK 2015 103TC international model.
Currently I have loaded a stock improved map in the ECU with the power vision.
This is already a big improvement over the stock international map.Runs super smooth.
Autotune is on the program as soon as the road salt is gone.
Thanks .
Thanks .
#8813
I have a problem with my PV and this is happening for the first time. When I connect it to Win10 Pro 64bit, the Dynojet logo comes on the screen of the PV and starts flickering, when I press and hold the red button the PV it goes to Recovery Mode.
Here is a video...
https://www.dropbox.com/s/19m6b6z9ry...%20PM.mov?dl=0
Any help will be highly appreciated.
Here is a video...
#8814
Merry Christmas to you all...
Update:
Dynojet technical support were very responsive, they replied to my email and sent me a recovery file to download and steps of instructions to follow, but the recovery process would not finish and it interrupts after about 3 minutes.
Here is a video showing in Recovery Mode and when the PV starts the recovery process...
https://www.dropbox.com/s/g8y7jyg5dz...%20AM.mov?dl=0
I thought the issue is with Win10, I tried the recovery process on Win7 and was the same...
Update:
#8815
PE settings
Does anyone know if certain cal strategies use different PE settings. I read up a little on this part of the tune and someone hinted that different cals and different combos would have different settings. But, I couldn't find anything that got specific.
I got a tune from a supporting forum vendor. The PE Enable RPM was set at 6500 RPM from the vendor, which leads me to believe that they pretty much disabled PE from being a player in this tune. I had another another issue with the cal they sent so needless to say I've lost some faith in what they tell me.
I would like a better understanding of why they did that and if it needs correcting.
Thanks
Thanks
#8816
#8817
you can see some of the items with the PV hooked up to your laptop but not a lot.
#8818
You can also hook it up to your computer, start winPV, click on Power Vision/Diagnostic/exit PC Link Mode. And it should stay on to learn the screens. (at least it used to)
#8819
