Connecting to fuse box
Old 02-05-2007, 11:49 PM
BrianK's Avatar
BrianK
BrianK is offline
Default Connecting to fuse box
Anybody know what kind of connector I need to plug into the bottom of a HD fuse box? I want to connect a tach to the unused "P&A" fuse, but the danged box is in there so snugly that while I could get a wire/terminal plugged into the bottom, I can't turn the danged thing upside down to see what sort of terminal fits in there.
Thanks folks. BrianK
Old 02-06-2007, 01:03 AM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
Default RE: Connecting to fuse box
Brian,
I did the same thing and I think the correct terminal came with the tach kit, but I can't remember what kind it was. I'll look for the instructions and see if it shows what kind it was.
Jim
Old 02-06-2007, 09:26 AM
BrianK's Avatar
BrianK
BrianK is offline
Thanks Jim! - BrianK
Old 02-06-2007, 05:30 PM
stang66convt's Avatar
stang66convt
stang66convt is offline
1st Gear
also trying to figure out a way to hook up a tach to an 05 fat boy
Old 02-07-2007, 12:00 AM
Jim Dawson's Avatar
Jim Dawson
Brian,
My instructions just say to insert the terminal on the end of the Orange/White wire in the empty side of the P&A IGN fuse cavity in the fuse block. One side already has a terminal and wire in it, the other side is empty. The instructions don't show what kind of terminal it is. I have the electrical and service manuals, I'll look there and see if they say anything.
Jim
Old 02-07-2007, 12:10 AM
Jim Dawson's Avatar
Jim Dawson
The electrical diagnostics manual gives the following part numbers for the fuse block terminals but no pictures:
Terminal part number 72279-04 for 14-16 gauge wire
72286-04 for 12-14 gauge wire
72309-04 for 16-18 gauge wire
Maybe the dealer will have the terminals and you can see what they look like. Sorry I couldn't be more help.
Jim
Old 02-07-2007, 02:23 PM
BrianK's Avatar
BrianK
BrianK is offline
Jim, thanks very much. This is helpful, and it was very thoughtful of you to go to the trouble to look it up. - BrianK
Old 01-10-2013, 12:37 PM
zues's Avatar
zues
zues is offline
you guys are a big help, the dealer in my area said they dont have those terminals. i will call them with part number and see, thanx
Sal C
08-28-2020 10:51 PM
cajun1957a
11-07-2017 04:06 AM
sniper77
12-12-2009 02:36 PM
richdeerht
11-13-2008 06:13 PM
softailer
07-04-2008 12:33 PM
Quick Reply: Connecting to fuse box
