Neutral light on constantly
Old 03-20-2017, 03:47 PM
ral819's Avatar
ral819
ral819 is offline
Default Neutral light on constantly
Noticed I have a neutral indicator lit constantly, bike shifts ok but no cruise control. What sensor would be bad ? Gear position?
Old 03-20-2017, 03:53 PM
lp's Avatar
lp
lp is online now
Received 2,722 Likes on 1,547 Posts
Probably your neutral switch located on the top of the trans case.
Old 03-20-2017, 06:02 PM
69cj's Avatar
69cj
69cj is offline
Not under warranty?? Just take it back.
Old 03-20-2017, 06:31 PM
timbo141's Avatar
timbo141
timbo141 is offline
You need to have your left switch pack replaced under warranty. Water got inside. Same happened to me and others.
1. No gear indicator.
2. No start with clutch pulled in (in gear) and only starting in neutral.
3. Cruse not working.
These symptoms are a telltale sign you have a bad left switch pack.
Or two out of three, and eventually all three will show up.
Good time to put lighted switch packs in if you choose. You will have to pay the difference.
Old 03-21-2017, 04:06 AM
ral819's Avatar
ral819
ral819 is offline
What I noticed was my cruise shutting off on the highway, The Engine was pretty hot. It acted normal when cooled down ? Started with clutch in and in gear, fine. Just indicated Neutral all the time when hot. I could put some pressure on the shifter and it would go out and indicate the gear. Lighted switch pack ??? New one to me.
Old 03-21-2017, 11:29 AM
timbo141's Avatar
timbo141
timbo141 is offline
http://www.harley-davidson.com/store...ntrol-switches
Old 03-23-2017, 09:22 AM
smitty901's Avatar
smitty901
smitty901 is offline
Received 9,622 Likes on 5,178 Posts
If it is a 2017 it is under warranty . Let them fix it. Contrary to what you hear HD is dam good on warranty.
I would lean toward the N switch no big job .
Old 03-23-2017, 06:18 PM
BrokenAnchor's Avatar
BrokenAnchor
BrokenAnchor is offline
I agree with the others, it's under warranty, take it in and let them have a look at it. When you buy a new scoot, you should expect it to perform as designed.
Old 03-27-2017, 07:26 AM
ral819's Avatar
ral819
ral819 is offline
I've been riding with no issues , Temp is around mid 50's to mid 60's and not a problem was noted. Just when the Temp got up to 80 degrees, did I notice a problem. The engine was definitely hot. I thought maybe I could reproduce the same thing. Ran like a dream... I'm going in Tuesday for this issue.
Rustrtal
2014-2023 Touring Models
07-24-2018 08:52 AM
DBahr
04-22-2018 09:07 PM
Ultraskier
21
08-10-2017 10:34 AM
cajun1957a
04-18-2016 06:56 PM
skydrifter
01-22-2010 03:42 PM
Quick Reply: Neutral light on constantly
