going flat (not black)
i googled all i could, and i searched on here, maybe not thoroughly but hopefully i could get some quick insights.
i plan on painting my ride coyote tan, like an MRAP. any of my brothers from motor-t on here id like to match the scheme. reading in to much ive been told to primer and wet sand of course, then ive heard that you use surfacer, then primer if you want that "pop" to the color. now, MRAP coyote tan dosent "pop". its got that undertone, that "i dont wanna be here" shade to it. on the same token, i dont want to do a crappy paint job. so im not sure what is the best way to ensure that its not gonna look homemade but not look "im ready for stugis".
"but it is homemade, you're doing it" true, but i have a paintbooth with a dustcollector/ fan, professional sugar blaster, and vacuum powered paint guns. also got that TCP "kustom" desert storm tan and hot rod flat black kits along with an over all hardener - been told i should, or dont have to use that, no idea. and two cans one says medium urethane reducer *70deg mid temp* and fast urethane reducer *60deg cool temp*. im guessing the hardener is to make it cure faster, and i should use the mid temp medium reducer since this will be indoors and the temp is kept around about there at all times.
all the flat painting ive looked up is always for black. but im not trying to imitate SOA and looking for a specific look to my flat tan. any and all help is appreciated. thank you.
hot rod flatz makes some very easy to work with and shoot paints exp if you are not very exp with painting, however people think flat is easier to shoot when it is not, you have to get it right out of the gun you can not fix issues with your cut and buff stage as you do not have one... we powder tins all the time and use custom flat finishes
i have vacuum guns, i have a buddy of mine getting me a gravity fed so ill see what works best from there.
all i have to go on now is primer, wet sand, paintx2, flat coat, done. i youtubbed for hours last night...every-single-person had a different way "that was better". its paint, flat paint, one color, **** me.
After you flat cleared the paint did you cut/buff or wetsand? I'm wanting to do one of mine in flat white and trying to gather up some info.
After the flat clear you don't touch it. I was told that on these flat or denim paints that if you wet sand, cut, buff, or wax it will turn them into gloss. If you notice in the first pic I laid the base coat down and its a gloss. It wasnt till after I laid the clear on that you get the Denim or flat look.
You pretty much have to get it right the first time. With these flats, you can go back and fix errors without sanding all the way down and starting completely over.
Wow nice job for never spraying before! Laid out very nice, and the black exhaust really sets it off!
THANKS !
I was always told that when it comes to painting, its all about the prep. Well, I took my time to make sure everything was prepped properly. My local paint and body supply store, whom mixed the paint, really went above and beyond in going over with me the process not only as a whole but for the product I bought. A big shout out to those guys ! Other than that I just took my time with everything. Patience really is the key. DO NOT GET IN A RUSH !
I really like the Vance & Hines exhaust. Probably going to black out the headlight nacelle and the uppers of the forks. I'm having BR Customs build me some apes and new risers now.
