Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
Considering painting my bike
Old Jun 7, 2019 | 12:08 AM
shaung's Avatar
shaung
4th Gear
Default Considering painting my bike
I’m curious to see if anyone’s painted their bikes and what did it cost you? I’ve got a vivid black street glide and would rather go with maybe a silver or burgundy color.
Old Jun 7, 2019 | 10:45 AM
Magnut1's Avatar
Magnut1
Just finished my winter project. Cost about $240 in materials. I used ColorRite Rattle cans. Good quality. Lots of wet sanding and polishing by hand. I am pleased with it. if you go conventional, you will have about $600 - $1000 in materials. My bike was vivid black and I went with Starlight Black metallic. If you go with silver, you could use gray primer, burgundy, use red primer. I didn't use primer unless I had a chip or scratch repair, except on the rear facia. I bought it used and it was pretty messed up from someone trying to paint it.
Old Jun 7, 2019 | 09:34 PM
1997bagger's Avatar
1997bagger
If you don't paint very often Silver isn't a color you want to tackle, it is prone to tiger stripe unless you have good equipment and experience plus shows any little flaw in prep work.
With using quality Urethane paint metal flakes paint will cost $200 a qt for color, $200 for clear coat needing $225 for activator and $40 for reducer. Solid colors just remove the cost of clear but will still need the activator
Old Jun 7, 2019 | 09:52 PM
1997bagger's Avatar
1997bagger
Donated a paint job to a good friend using a Chromabase Urethane system. Equipment helps, quality paints makes a difference and knowing your products characteristics is golden
RoyB
Jul 10, 2018 10:48 AM
Deputyrj
Sep 22, 2017 10:39 PM
buellrider76
Jan 15, 2015 02:40 PM
steveh326
Jun 10, 2010 07:48 AM
Punk09Rocker
Apr 21, 2010 09:45 PM
