Variable pressure clutch
Just upgraded to a 107" big bore kit and cams from fuelmoto. They recommended a heavy duty clutch spring so I went with it. The clutch is holding fine with this setup however the clutch pull is a bit harsh at red lights and such. My question is, how much better is the clutch pull if I keep the Barnett HD spring and install an AIM 68LT variable pressure clutch? Any advice is appreciated here. Thanks!
I've been using a 107" with stronger spring for a while and agree with you, the lever pressure is getting a bit too much! I've bought an AIM, although have yet to fit it. I haven't seen any comments about them being a problem. As you have a later bike than mine there are other devices that reduce lever effort, so keep looking. There is one that I can't use on my older bike, but would be suitable for yours - unfortunately I don't recall the brand.
